Thread: Access to drivers rear door
  1. Access to drivers rear door
    Dec 2012
    West Yorkshire
    Hi all,
    Hope that someone can help, the issue that I have is to do with the drivers side passenger door.
    The door has a child lock on and recently there has been an issue with opening the door from the outside.
    As such I now cannot open the door at all, anyone point me in the direction of a solution, as having no access from that door is proving to be a nightmare.
    Al help great fully received
    Gurj
  2. Re: Access to drivers rear door
    Leics
    When the door locks start to play up it is best to get them replaced before they stop working completely, otherwise the only way in is by cutting through the interior door card which is expensive.
  3. Re: Access to drivers rear door
    Oct 2005
    Try striking the door with the palm of your hand close to the lock area - sometimes you get lucky and the door will open.
    If not you'll have to do as ChicksFan suggests and cut into the door card.
  1. Please Help Rear Drivers side Passenger Door
    By worthingbloy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 05:20 PM
  2. Question Does anybody know how to remove the rear passenger door trim card for access to window mechanism?
    By luckystrike in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-09-2009, 05:50 PM
  3. removing the rear drivers door, please help
    By nickandcath in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2009, 10:43 AM
  4. Rear drivers door locked shut.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-02-2009, 03:44 PM
  5. Drivers side rear door locked
    By Fettler in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-04-2008, 10:33 AM
