Thread: vacuum pipe attatched to servo pipe
  1. vacuum pipe attatched to servo pipe
    I've been experiencing brakes going hard when pressing the brake pedal so decided to check the servo hose which goes from the servo to the vacuum pump.
    There is a vacuum pipe which tees off the servo hose. Can anyone tell me where the other end of this pipe connects to as its currently hanging loose.
  2. Re: vacuum pipe attatched to servo pipe
    not sure if this will help .. but here goes .. B5 VACUUM HOSE DIAGRAM - PASSAT
  3. Re: vacuum pipe attatched to servo pipe
    Aug 2011
    Meath
    Pedal going hard can be caused by water in the plenum chamber rusting the servo. Test it by pumping the brakes with the engine off until the pedal gets hard. Keep your foot on the brake and start the engine, if the pedal stays hard it's probably the servo a fun Saturday morning project!
  4. Re: vacuum pipe attatched to servo pipe
    Jun 2013
    Ireland
    I know this is somewhat an old thread but if its anything similar to my AVB type engine the small vacuum pipe that tees off from the brake servo tube supplies the N18 solenoid valve with vacuum. Leaking that vacuum would have the effect of loosing servo assist on your brakes but should also cause the car to go into limp mode as the turbo and EGR valve are controlled using that same vacuum.
    Jim
  1. What's this vacuum pipe?
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2013, 09:42 PM
  2. Vacuum pipe or not?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2011, 03:47 PM
  3. Damaged vacuum(?) pipe
    By screamer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2009, 07:38 PM
  4. Polo/Lupo brake servo pipe.
    By westie383 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 11:34 PM
  5. Vac Pipe to Brake Servo
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:07 AM
