Thread: Key working and programmed to car but still remote locking wont work
Results 11 to 20 of 23
  1. Re: Key working and programmed to car but still remote locking wont work
    Colchester,Essex
    If you find it dump under the carpet take the CCM out of the black box,let it dry by opening the CCM box carefully,refit and try again,also under the bonnet take the plastic cover off the pollen filter and battery,check for drainage blockages by dirt and leaves etc clear it,check fro cracked pollen filter housing.If there is no wet or dumpness then try resyncing as Chris said.
  2. Re: Key working and programmed to car but still remote locking wont work
    May 2010
    billingham
    Are you talking about recyncing procedure for the key?
  3. Re: Key working and programmed to car but still remote locking wont work
    46 Post(s)
    Try the resyncing first, could save a lot of hassle.
  4. Re: Key working and programmed to car but still remote locking wont work
    Colchester,Essex
    By the way,just because I work for an Audi dealer won`t make me a Guru,could`ve been a spotty little apprentice who delt with it.
  5. Re: Key working and programmed to car but still remote locking wont work
    May 2010
    billingham
    Are you talking about resyncing the key?
  6. Re: Key working and programmed to car but still remote locking wont work
    May 2010
    billingham
    Quote Originally Posted by turpal View Post
    I will try this and hopefully it will work.thanks
  7. Re: Key working and programmed to car but still remote locking wont work
    #17
    Aug 2011
    Meath
    You don't need a laptop to synch the key anyway
  8. Re: Key working and programmed to car but still remote locking wont work
    #18
    46 Post(s)
    I'm guessing a new key was matched to the car and the resync with the central locking wasn't done.
    1 2 0
  9. Re: Key working and programmed to car but still remote locking wont work
    #19
    May 2010
    billingham
    Quote Originally Posted by Doctle Odd View Post
    Sorry I wasn't as clear as I could have been. The guy tried syncing the key a couple of different ways and because they didnt work then he reprogrammed it using the laptop. The program said that the car has accepted the key but the key still would not work
  10. Re: Key working and programmed to car but still remote locking wont work
    #20
    May 2010
    billingham
    It's the same key ie had since owning the car and it worked fine when I first got it. One day it just stopped working
  1. Replies: 2
    Last Post: 26-12-2016, 07:27 PM
  2. Remote Locking Not Working - Key Re-Sync?
    By Blacktemplar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-04-2013, 06:12 PM
  3. remote wont work after disconnecting battery
    By BOD0001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2010, 08:57 PM
  4. Will a remote key fob work on my car?
    By wingnut106 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 04:27 PM
  5. My Remote locking key fob deson't work, any ideas?
    By POLO Dead Wanna PASSAT in forum Passat - Archive Topics
    Last Post: 01-09-2006, 03:48 PM
