Thread: Error code 01393 g84
Results 1 to 10 of 10
  1. Error code 01393 g84
    Jun 2013
    Ancaster canada
    I've been trying to narrow down this error code online with no luck. Anyone have any ideas? No interior warning lights on so far.
  2. Re: Error code 01393 g84
    Nov 2009
    46 Post(s)
    16955/P0571/001393 - Ross-Tech Wiki
    Have you cleared and rescanned?
    Check all brake light bulbs etc.
    Welcome to VWAF.
  3. Re: Error code 01393 g84
    Jun 2013
    Ancaster canada
    Scanned and cleared multiple times. I've attached a photo on the error (I think) on the handheld unit. Sensor for level control indicated as issue.
  4. Re: Error code 01393 g84
    Nov 2009
    46 Post(s)
    Well that code is coming back to the brake switch on rosstech.
    Is there any chance you could get it scanned with VCDS or Audi?
  5. Re: Error code 01393 g84
    Jun 2013
    Ancaster canada
    I can. I'll have to take it in to a dealership. What indicators would there be if the brake light switch was faulty?
  6. Re: Error code 01393 g84
    Nov 2009
    46 Post(s)
    It's all in here - 16955/P0571/001393 - Ross-Tech Wiki
    Do the brake lights work? Cruise control etc?
    I'm not sure if that 01393 code is specific to that reader so the above could well be incorrect.
    Do you have the manual for that Maxscan?
    If it is indeed the sensor for the level control, does the air suspension work correctly as it should? Rises up and down etc?
    Could be your Xenons - do they go up and down when you switch them on when the car is started?
  7. Re: Error code 01393 g84
    Jun 2013
    Ancaster canada
    Side note, when error present, the key will not come out of ignition and information screen says to put car in park even though it already is.
  8. Re: Error code 01393 g84
    Jun 2013
    Ancaster canada
    I do, and the cruise is not working.
  9. Re: Error code 01393 g84
    Nov 2009
    46 Post(s)
    Quote Originally Posted by Shumphrey12 View Post
    I know on other Audi models, when the cruise doesn't work then the brake switch is the first thing everyone checks.
  10. Re: Error code 01393 g84
    Jun 2013
    Ancaster canada
    Ok, I'll look into the brake switch. Thanks.
    Suspension works fine, little creaky, but fine.
  1. error code gone - still not right?
    By the lemster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-08-2012, 09:58 PM
  2. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  4. Error code help
    By dysonco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 12:34 AM
  5. Question error code
    By mark53 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2008, 10:22 PM
