Thread: RNS-E aerial
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: RNS-E aerial
    Aug 2009
    Near Lanark
    21 Post(s)
    I've been lucky enough to find another member close enough and he kindly scanned my car (Thanks Saq!)
    Here's the single error thrown out by vagcom.
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
    Component: RNS-E HIGH EU H72 0650
    Revision: 01S Serial number: AUZBZ7F1152650
    Coding: 0309717
    Shop #: WSC 06325 000 00000
    VCID: 2C514BBB8CA84A7E01D
    1 Fault Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 216
    Time Indication: 0
    Date: 2012.06.16
    Time: 15:41:17
    Freeze Frame:
    Mileage: 655350 km
    Count: 1506
    Clock: 14:22
    I've sussed that the antenna booster fails and it looks like mine has failed.
    So my questions are
    1 - is it expensive?
    2 - if it is, is there an aftermarket equivalent?
    3 - is it easy/diy?
    I have no idea what's involved but would upgrading to a DAB be worth it if it means I can avoid changing the antenna booster?
    Thoughts and ideas welcome!
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  2. Re: RNS-E aerial
    Jan 2012
    Coding Something
    Just replace the amp if its failed, costs yes, but at least its all working as per the system requires.
    DAB will plug into existing circuit & it just goes in line with the existing antenna connections & essentially just cuts of any other reception whilst dabs turned on, depending on the implementation, it uses the same principle as an fm transmitter for say ipod except cabled, so comes in under 1 frequency & you can maybe get mfsw control to the dab or an ir remote.
    As I said depends on implementation as to what interaction you get, for me I'd just get oem working again.
  3. Re: RNS-E aerial
    Aug 2009
    Near Lanark
    21 Post(s)
    Am I right in saying the part is around £200???
    Isn't there an after market version?
    thanks
  4. Re: RNS-E aerial
    Jan 2012
    Coding Something
    You'd need to remove the part to confirm part number & then price, if you sell it on then it will only come up as a negative anyway.
  1. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  2. Installation of AUDI bluetooth kit for RNS-E RNS
    By 519ryan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-05-2011, 09:14 PM
  3. Rns d to rns e conversion
    By aristidis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2009, 11:29 AM
  4. Upgrade from RNS-D to RNS-E
    By chrisroffey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-07-2009, 02:16 PM
  5. rns-d sat nav to rns-e stav nav
    By hockey1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2008, 12:19 PM
