Thread: Right Rear Turn Signal Warning when switching ignition on with lights activated
Results 1 to 10 of 11
  1. Right Rear Turn Signal Warning when switching ignition on with lights activated
    Hope someone can shed some light on this (no pun intended). For some time I have had what I thought was an intermittent issue with the 'Right Rear Turn Signal' warning on my B7 Avant, when I switched the car ignition on. Over the weekend I worked out that it was only occurring when the head/tail lights were also on when the ignition was started. I have auto lights - hence the reason I originally thought it was an intermittent error.
    I have tested it several times and it happens whether the headlights, or sidelights are on when the ignition is activated, whether on auto or manual. It does not happen if the ignition is activated and the headlights are subsequently turned on. When it does happen, simply activating the right turn signal clears the error. The indicators work 100% of the time.
    I've scanned the car with vag-com with the error present in the dash, and without. Without it there, vag-com reports no error. When I scan it with the error present, it reports the following fault code:
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0504
    Coding: 11001
    Shop #: WSC 65536
    VCID: 3B68236F295B8FC0359
    1 Fault Found:
    01505 - Bulb for Blinkers; Rear Right (M8)
    30-00 - Open or Short to Plus
    I've tried cleaning the bulb contacts, and replacing the bulbs too, neither seems to help. To my simple mind, it appears that when the headlights are on, and the system tests for errors when you activate the ignition, the headlights seem to be blocking or interfering with the result when the turn signal is tested.
    What I don't know is what to do to fix it?!
    2006 A4 Avant S Line
  2. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Huddersfield, West Yorkshire.
    If I was you I would check where the wiring loom comes in at the top of the boot, possibly a partially broken wire in there. Although i've never had this on Audi's I have fixed lots of broken wires in golf boot lids.
  3. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Quote Originally Posted by discobarry View Post
    Thank you. I'll try and check it out tomorrow and update if I find anything.
  4. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Southern County Softy
    20 Post(s)
    Could be the switch.
    If you need one check the part number of yours, I may have one kicking about.
    bloody interweb phone.
    A4 2.5 tdi QS (mapped)
  5. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Quote Originally Posted by kite View Post
    Thanks for the reply. Apologies if I'm being a bit dim, but when you say switch, what exactly are you referring too, and how do I check it?
    Whilst I'm not a total novice (been messing with vw's and audi's for a few years now), I'm better with the mechanical and swappable parts than I am the electrics!
    thanks in advance
  6. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    20 Post(s)
    As your fault changes depending on the position of the light switch it could be the problem.
  7. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Oct 2010
    walsall
    After reading this i would look at the earth around the rear light cluster, front and rear indicators are connected so if it was a switch fault the front indicator would come on with the rear, a bad earth would localise the fault.
  8. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    Got you. Now I come to think of it, I did notice the yellow 'auto' light start flickering mid-drive a few weeks ago. Definitely worth a closer look...
  9. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    I had the switch out, couldnt see any obvious fault with the parts I could take apart. The label on the side has the part no: BK7 8E0 941 531 D 01D
  10. Re: Right Rear Turn Signal Warning when switching ignition on with lights activated
    20 Post(s)
    I'll send you a PM.
  1. Can you turn on Rear Fog Lights without the Front ones?
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-11-2011, 08:52 AM
  2. Turn signal problem???
    By knight A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2009, 09:38 PM
  3. Older A6 Electrical Problem (Rear and Signal Lights)
    By eXzenTrix in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-01-2009, 11:47 PM
  4. Turn signal problem
    By a6rob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-04-2008, 04:52 PM
  5. Turn Signal Indicators
    By WesleyP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2007, 10:51 AM
