Thread: Can not take the original concert stereo out with removal key
Hybrid View
  1. Can not take the original concert stereo out with removal key
    Mar 2008
    Coventry
    Hi Guys
    I have got the Audi A4 1.9 TDI Sport 51 Reg, i am trying to take the original concert stereo out to replace it with aftermarket head-unit.
    I have got the removal key for the stereo, however, it don't seems to help, key goes in and clicks but when i pull it out at the same time, its just stuck only key slips out
    I would like to know if anyone else had this problem before in the past? or is there are another ways to remove the stereo?
    If yes could you please give me clear instructions / video you may have.
    Thanks for your help in advance
    Br
    Vasi
  2. Re: Can not take the original concert stereo out with removal key
    46 Post(s)
    Get yourself these - RADIO REMOVAL KEY TOOL FORD VW AUDI BMW MERCEDES BECKER BLAUPUNKT SKODA | eBay
    I had the same problem and a good quality set like that (which I also purchased) shows no problems.
  3. Re: Can not take the original concert stereo out with removal key
    Mar 2008
    Coventry
    Hi Chris
    Thanks for your advice, ill give these go
    br
    Vasi
  4. Re: Can not take the original concert stereo out with removal key
    Feb 2013
    Swindon
    Take the glove box out (only 5 bolts) then you can reach in and push the stereo from behind when your current keys are located.
  5. Re: Can not take the original concert stereo out with removal key
    Mar 2008
    Coventry
    Thanks Ajrayner
    I have managed to remove the Stereo,
    Now i am trying to fit the after market head unit pioneer MVH 350BT. But been told that i have a Bose system in place and will need special adapter to go with it,
    Could you guys give me an idea what adapter i need and where do it get it from part number ECT...
    Vasi
  6. Re: Can not take the original concert stereo out with removal key
    Jul 2013
    Rugby
    If I'm right you need quickfind code 28386 on caraudiocentre dot co dot uk
    I think..
  1. Retro fit Bose where is the original concert amp?
    By 70325 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2012, 11:00 PM
  2. Stereo removal key jammed - help!
    By gcltd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2010, 09:35 PM
  3. I pod conector to original stereo
    By superkev in forum In Car Entertainment
    Last Post: 12-08-2009, 08:39 AM
  4. Hi,mp3 player to original gammer stereo is it possibe???
    By tonyleach in forum Golf MK4 - 1999 - 2004
    Last Post: 21-05-2008, 07:59 PM
  5. Wanted!!! Original Stereo Headunit 97 A4 B5
    By Lofty79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-04-2008, 09:32 PM
