Thread: transporter t4 timing belt disaster!
  1. transporter t4 timing belt disaster!
    Aug 2007
    hi there,
    i have a 1993 vw transporter t4 1.9d which has served me great so far until yesterday! Unfortunately the timing belt has snapped which the ever so helpful rac bloke told me, may have led to engine damage. Is there anyone out there who could tell me whether i should be going straight to a garage or can i start to tackle the job myself given that i have ne reference to where the pulleys should be aligned?
    Any suggestions would be muchos appreciated!!!
  2. Exclamation Re: transporter t4 timing belt disaster!
    Aug 2007
    if ur timing belt has broke , then in regardless of wat speed u were doing , u have bent a few valves either replace the head , valves or if u get a cheap engine, but best is if u replace the valves , atleat u know wat work u have done to ur engine, if u need valves , i have some !
  3. Exclamation Re: transporter t4 timing belt disaster!
    Aug 2007
    also u will need to replace the cambelt tensioner , which is advisable
  4. Re: transporter t4 timing belt disaster!
    Aug 2007
    hello bling 69,
    Thanx for the suggestion. I was hoping to just replace the belt correctly and go from there but i guess it could be a much bigger job then? I feared the worst! Will report back as soon as i know plan of action.
  1. VW Transporter 1993 Injection pump timing belt problem.
    By Bambiboy in forum The Commercial Range
    Last Post: 28-05-2009, 02:21 PM
  2. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  3. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
  4. Transporter 2.5 TDI - Timing Belt diagram
    By SMC in forum The Commercial Range
    Last Post: 20-09-2006, 11:42 AM
  5. Timing Belt
    By hog883 in forum The Commercial Range
    Last Post: 06-03-2006, 10:12 PM
