Thread: Power Steering Help Please
Results 1 to 10 of 14
  1. Power Steering Help Please
    Mar 2008
    Warminster
    Hi Guys
    wifes tdi 130 golf, sat at tickover then go to move with steering on full lock and it starts screeching, take it slightly off full lock or give it some revs and it goes. Now i was always told its not good to turn a car with the steering full lock on the stop but it hasnt always made this noise, plenty fluid, is the pump starting to struggle/on its way out
    cheers Paul
  2. Re: Power Steering Help Please
    Pembrokeshire
    22 Post(s)
    when it screeches, does the belt tensioner jump about ?
    i ask because it could be the clutch pulley on the alternator seized up. use a thin pointy thing and see if you can turn the fan on the alternator, the bit through the case, in one direction and not the other.
    2 0 0
  3. Re: Power Steering Help Please
    Mar 2008
    Warminster
    Cheers Zollaf will give that a go, love the technical description of a "thin pointy thing".
  4. Re: Power Steering Help Please
    Mar 2008
    Warminster
    The red arrow i assume is pointing to the tensioner, the belt seems to be jumping about at the point of the blue arrow where the belt comes off the pulley. The pully on the alternator, above the blue arrow seems ok.
    thanks for the help guys
  5. Re: Power Steering Help Please
    Mar 2008
    Warminster
    Ive put a pointy thing through the slots at end of the arrow and the fan doesn't want to move either way
  6. Re: Power Steering Help Please
    Mar 2008
    Warminster
    And this is i link to a video of the belt tensioner and the noise it makes, double click the pic.
    http://
  7. Re: Power Steering Help Please
    Pembrokeshire
    22 Post(s)
    aye, pulley locked up. a new one is about 60 notes but you do need tool to change it and preferably a windy gun. if you have 3 inches room in front of the pulley yo can get the tool in, if not you have to remove the alternator.
    2 0 0
  8. Re: Power Steering Help Please
    Mar 2008
    Warminster
    Cheers Zollaf
    is that the pully on the front of the alternator or the tensioner pully, and can you point me in the direction for the correct tool to change it please
    many thanks Paul
  9. Re: Power Steering Help Please
    Pembrokeshire
    22 Post(s)
    the pulley on the alternator. its a one way clutch, so if you stop the alternator turning inside, like holding the fan, you shoulb be able to turn the pulley one way but not the other. or, as the belt stops the pulley turning, you should be able to turn the fan one way but not the other.
    the tool is just past sainsbury's on the left
  10. Re: Power Steering Help Please
    Pembrokeshire
    22 Post(s)
    BOSCH ALTERNATOR PULLEY TOOL, Freewheeling pulleys | eBay
    and looks like this. the spline goes into the actual pulley, the long thing holds the end of the shaft. with windy gun you just use the big spline bit.
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  3. Power Steering
    By Daz Seaton in forum Golf MK5 - 2004 - 2009
    Last Post: 26-05-2010, 10:42 PM
  4. power steering
    By william young in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-01-2009, 10:21 AM
  5. Power Steering
    By wezzo in forum Archive posts
    Last Post: 30-12-2007, 01:47 AM
