Thread: 1.8t link to correct engine oil?
Results 1 to 10 of 10
  1. 1.8t link to correct engine oil?
    May 2013
    England
    Hi am getting my 1.8t auto serviced the annual service for the first time and am getting very confused with all the different grades etc that keep poping up when I look into it. Can anyone supply me a link to the best oil recommended for my engine please.
    Many thanks
  2. Re: 1.8t link to correct engine oil?
    134 Post(s)
    2019 Post(s)
    Just go to your local VAG TPS or Audi dealer and get a 5 litre bottle of Quantum Platinum 5w/40 and an oil filter, doubling up the oil changes on your particular engine (the 1.8T) is absolutely critical.
  3. Re: 1.8t link to correct engine oil?
    Apr 2011
    Bourne, Lincolnshire
    Crasher is spot on with the oil choice in my view. I do an annual oil change regime in my 1.8t and use Platinum which does the job perfectly.
    My only added advice would be to buy the larger oil filter part no. 068 115 561F. This filter (for the TD versions) is larger than the one originally specced for the 1.8t and gives you larger oil capacity to enable it to stay cooler.
    This larger filter is widely used in the 1.8t, along with other measures,to avoid oil sludging. If you aren't aware of this issue, then I would recommend some web searching, especially with regard to oil pickup (strainer) blockages.
    Steve
    1 1 0
  4. Re: 1.8t link to correct engine oil?
    134 Post(s)
    2019 Post(s)
    Yes, without exception we use the diesel filter on the longitudinal 1.8T (we did one last week) but it is not specified for the transverse which is much less prone to this problem although it is listed as being an option although the space is rather tight, especially on cars with the secondary air injection pump.
  5. Re: 1.8t link to correct engine oil?
    May 2013
    England
    Okay many thanks for the great help what is the price roughly of the oil and filter from audi and is it something they have on the shelf?
  6. Re: 1.8t link to correct engine oil?
    134 Post(s)
    2019 Post(s)
    The oil filter retails at £13.26, I don't know what the oil costs.
  7. Re: 1.8t link to correct engine oil?
    May 2013
    England
    Castrol Edge Fully Synthetic 0W30 Engine Oil (4 Litre)
    any thoughts on the above? Is this suitable for my model I've always had good things to say about castorl in the past
  8. Re: 1.8t link to correct engine oil?
    134 Post(s)
    2019 Post(s)
    Yes that's fine but it is LongLife spec and so do not use it for that interval, change it every 5K miles on your car. The grade is of secondary importance with your engine, interval and filter type are paramount. The best oil in the world will not let your engine survive abuse.
  9. Re: 1.8t link to correct engine oil?
    Colchester,Essex
    I`d stick to 5w40 platinum and change it half way.Oil pick up problems usually start at around 80-90k miles but subject to individual car maintenace so worth checking to avoid the expensive repairs.I believe quantum is made by castrol but happy to be corrected.
  10. Re: 1.8t link to correct engine oil?
    134 Post(s)
    2019 Post(s)
    A 205 litre barrel of Platinum I had once did have Castrol in tiny writing on the label.
  1. Question What is the correct amount of Engine Oil required?
    By paddyjoesoap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2010, 10:12 PM
  2. Question Services & Correct engine oil for 2006 1.2 polo
    By uknp5478 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-10-2010, 10:33 PM
  3. correct engine oil
    By monkgti in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2010, 11:07 AM
  4. Question Correct engine oil for 2001 TDI Caravelle (AUF engine)
    By guidoping in forum The Commercial Range
    Last Post: 11-04-2010, 09:26 AM
  5. Correct top-up engine oil?
    By Vib_analyst in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2010, 10:12 AM
