Thread: Instrument cluster flickering - infinite loop
  1. Instrument cluster flickering - infinite loop
    Aug 2010
    Auckland, New Zealand
    Hi all,
    I've got a 2004 A3 2.0FSI with a recurring 'insrument-cluster flickering' problem. Whenever I open the driver's door, the clock and trip meter light up and, after about 30 seconds, they go out. All normal so far. Straight after that, the speedo, tacho and cluster warning lights start flickering wildly for a few seconds like there's a loose electrical contact or something, and the clock gets reset to zero. After about 30 seconds of nothing happening, the whole episode starts again and it's like the car has got into some kind of infinite loop. Eventually, maybe an hour or so later, it stops. It's like the car is trying to go to sleep but keeps getting woken up as it's about to doze off.
    I get the same behaviour after I've been driving and just turn the ignition off. After about 30 seconds the cluster flickers for a couple seconds and heads off into the usual cycle.
    None of this happens when the ignition is on, with or without the engine running, and the clock and trip meter behave normally.
    I've had the cluster out and checked things like connectors and earth connections and I recently installed a new battery, but no change.
    I've done a bit of reading about CAN bus and understand a bit about the CAN gateway telling different modules (including the instrument cluster) to go to sleep. For what it's worth, I found that the 2004 A3 has a dedicated line between the gateway and the cluster for exactly this purpose. Apparently, later models don't use a dedicated line.
    I've had access to VAG-COM and include a printout below. There do seem to be issues with communication between the CAN gateway and the instrument cluster.
    Do any of you Audi geniuses out there have any clues what's going on or any ideas on what I could try to figure out for sure what's at fault? Any advice gratefully accepted.
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: WAUZZZ8P14A089447 Mileage: 66960km/41607miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Sporadic communication error 1000
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    Address 01: Engine Labels: 06F-906-056-AXW.lbl
    Part No SW: 06F 906 056 T HW: Hardware No
    Component: MED9.5.10 00 5407
    Revision: 00000000 Serial number: AUX7Z0C9FNA0IZ
    Coding: 0000075
    Shop #: WSC 06435 000 00000
    VCID: 3A71C3AC759126C82F1
    Part No: 06F 907 807 A
    Component: NOX 0309170034 004 3608
    06F907807A NOX 0309170034 004 3608
    4 Faults Found:
    16575 - Fuel Pressure Sensor (G247)
    P0191 - 008 - Implausible Signal - Intermittent
    18058 - Powertrain Data Bus
    P1650 - 008 - Missing Message from Instrument Cluster - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09G-927-750.lbl
    Part No: 09G 927 750 C
    Component: AQ 250 6F 0428
    Coding: 0000008
    VCID: 3163E480A8E7E5909EB
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent - MIL ON
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0053894
    VCID: 336FEE8852FBD780EC7
    1 Fault Found:
    00474 - Control Module for Immobilizer
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 HW: 8P0 820 043
    Component: KlimavollautomatH11 0130
    VCID: E9D3CCE0C0B7DD5016B
    3 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 199
    Mileage: 66078 km
    Time Indication: 0
    Date: 2012.01.23
    Time: 00:09:32
    Freeze Frame:
    Voltage: 14.10 V
    Temperature: 15.5°C
    (no units): 164.0
    (no units): 29.0
    Temperature: 12.0°C
    00796 - Fan for Interior Temp Sensor (V42)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 184
    Mileage: 66180 km
    Time Indication: 0
    Date: 2012.01.23
    Time: 00:31:50
    Freeze Frame:
    Voltage: 13.80 V
    Temperature: 27.5°C
    01206 - Signal for Duration of Ignition Off Time
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 184
    Mileage: 66968 km
    Time Indication: 0
    Date: 2012.01.24
    Time: 00:00:00
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H29 0501
    Revision: 00029000 Serial number: 00000000239578
    Coding: 008C4F00A0141000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7FC6A87AAB1FC0347
    Subsystem 1 - Part No: 8P2 955 119 Labels: 1TX-955-119.CLB
    Component: Wischer WWS Audi350 0130
    Coding: 16711696
    Shop #: WSC 00000
    1 Fault Found:
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0010603
    VCID: 458BA0500C6F5930523
    No fault code found.
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 009 0030
    Coding: 0010002
    VCID: EFE7A2F8FE53336048F
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 930 G HW: 8P0 920 930 G
    Component: KOMBIINSTR. VDO H25 0110
    Revision: D07 Serial number: 2249CD07008908
    Coding: 0002923
    Shop #: WSC 61800 981 64302
    VCID: 3669D79C4189C2A8CB9
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 24001039032931
    Coding: 3F0F0342070101
    VCID: 264907DC9129B2287B9
    3 Faults Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 142
    Reset counter: 224
    Time Indication: 0
    00381 - Databus Instrument Cluster
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 224
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 27
    Reset counter: 205
    Mileage: 0 km
    Time Indication: 0
    Date: 2012.01.23
    Time: 00:00:00
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D07 Serial number: AUX7Z0C9FNA0IZ
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8P0 959 801
    Component: Tuersteuerger. H10 0010
    Coding: 0000048
    VCID: F8F599A48B1D74D8995
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    Shop #: WSC 61800 981 63324
    VCID: 356BD0905C8FC9B0C23
    1 Fault Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Mileage: 66120 km
    Temperature: 23.0°C
    Voltage: 12.10 V
    Voltage: 11.90 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 A
    Component: KSG H02 0040
    Coding: 008800186D288505485A016000
    Shop #: WSC 07130 981 57096
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH23 0100
    Revision: 00001 Serial number: 10000001051267
    VCID: F0E5A184E36D2C98515
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8P0 959 802
    Coding: 0000048
    VCID: F9F39CA0B0176DD0E6B
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 B HW: 8P0 035 186 B
    Component: concert II JP H53 0060
    Revision: 07S Serial number: AUZ2Z3C1011224
    Coding: 0001001
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 152
    Reset counter: 224
    Freeze Frame:
    Bin. Bits: 10
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 224
  2. Re: Instrument cluster flickering - infinite loop
    46 Post(s)
    My dials flicker too sometimes when I turn the ignition on.
    Also when I turn the car on, it takes a few seconds for my instrument cluster to wake up after starting too. This happens probably once every 2 weeks. Odd.
    Can you clear all faults (Main menu, applications, erase all DTCs) then do a few ignition cycles and rescan?
  3. Re: Instrument cluster flickering - infinite loop
    Aug 2010
    Chris, I've already tried clearing all DTC's but, after a few ignition cycles, everything comes back the same as before. Thanks.
  4. Re: Instrument cluster flickering - infinite loop
    Near Blackpool
    48 Post(s)
    Sounds like a knackerd cluster to me... check ecu isnt underwater too
  5. Re: Instrument cluster flickering - infinite loop
    Aug 2015
    Nottingham England
    I've recently purchased a 2004 Audi A3 2.0 FSI and i am having the same problem you had. I just wondered if you were able to solve this issue and if so how?
    Thanks, Dan!
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 05:25 PM
  2. Help with Instrument cluster!?
    By keemaklan in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-03-2010, 07:42 PM
  3. B7 instrument cluster in a B6?
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2009, 07:13 PM
  4. Instrument cluster on the way out?
    By mrcheeezy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-01-2009, 12:34 PM
  5. Instrument Cluster
    By j4s0n88 in forum VCDS - General Questions
    Last Post: 03-10-2008, 06:36 PM
