Thread: Wiring location help
  1. Wiring location help
    Mar 2008
    Warminster
    Guys
    Im after some help please in locating the following from a 2003 Golf tdi 130
    1. Both rear abs sensor cables, i need to know whats on the other end, is it a connection block and if so where is it
    2. same as above but for front left abs sensor cable.
    many thanks Paul
  2. Re: Wiring location help
    Aug 2011
    Meath
    They are push in fittings the front is behind a grommet on the inner wing I forget where the rear wire connects I can't recall ever changing a rear wire
  3. Re: Wiring location help
    Mar 2008
    Warminster
    Ok hopefuly the rears will be the same, not too fussed about the front as the abs part is ok its the brake sensor part thats been cut but i can sort that with a block, but both rear abs cables have been cut in the past and rejoined with connectors that have corroded and i think this is whats causing abs light to come on, both sensors replaced so think im gonna get new cables if they aint too much.
  4. Re: Wiring location help
    Aug 2011
    Meath
    If you have enough cable, tin the ends, solder the cables and use shrink wrap to waterproof the joints. costs pennies
  5. Re: Wiring location help
    Mar 2008
    Warminster
    All sorted, car was in garage 6 months ago for abs lights on, ended up having new 2nd hand abs pump and a rear sensor which was £60 on its own. Last month abs lights on again so i got vag.com and scanned it and it picked up the other rear sensor and a wiring fault so when i changed all the discs i had a look to find that it seems as if both rear sensor cables have been replaced as they both had been cut an connected with bullet connectors which wernt in the best condition and neither were the plugs on the ends. I got another sensor off ebay for £6 and 2 new cables from VW at £45 each , fitted them and soldered the end of the wire back into the loom and shrink wrapped them, cleared faults and all good.
  1. Halogen to Bi-Xenon wiring adapter wiring diagram - might be useful for someone
    By kerbdog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-07-2016, 06:14 PM
  2. Replies: 0
    Last Post: 18-02-2012, 08:06 PM
  3. DV Location
    By rio_10 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-09-2011, 04:20 PM
  4. help location
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-07-2009, 10:56 AM
  5. Location
    By iallen1@btinter in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2008, 09:48 PM
