Thread: ESP Sensor Unit G419
Results 1 to 9 of 9
  1. ESP Sensor Unit G419
    Dec 2010
    Worcestershire
    A6 2.7 TDI Q 2006. Had traction light and 'ESP Fault' come up a few times intermittantly in quick succession followed by it becoming a permanent 'feature'. No other warning lights etc. Bit of a panic as MOT due in a month and have realised that this would now cause a fail.
    VCDS scan is showing the following faults:
    ddress 01: Engine Labels: Redir Fail!
    Part No SW: 4F1 910 401 HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0020
    Revision: --H02--- Serial number:
    Coding: 0011372
    Shop #: WSC 00618 210 91848
    VCID: DABF165B693B
    1 Fault Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 156176 km
    Time Indication: 0
    Date: 2013.05.30
    Time: 21:58:38
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.40 V
    Bin. Bits: 00101000
    Torque: 62.4 Nm
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H05 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    Shop #: WSC 02325 785 00200
    VCID: 2D550D87C835
    1 Fault Found:
    00493 - ESP-Sensor Unit (G419)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 156176 km
    Time Indication: 0
    Date: 2013.05.30
    Time: 21:58:58
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x02A2
    Hex Value: 0x0043
    Hex Value: 0x018B
    Hex Value: 0x00FF
    From what I can find out, it would seem that the first fault listed is actually due to the second one. Can anyone confirm this theory?
    If this is correct should I assume that the ESP sensor is faulty? I've read a variety of reports about where this sensor is located with the majority saying it is under the centre console somewhere.
    Any one else had a similar problem, advice on where it actually is and how to get at it, part no/code, best place for replacement (dealers?), idea of costs (no doubt it's £££££)
    all assistance greatly received.
  2. Re: ESP Sensor Unit G419
    46 Post(s)
    First fault is caused by the second.
    00493 - Ross-Tech Wiki
    Look under the heading no signal/communication.
  3. Re: ESP Sensor Unit G419
    Nov 2012
    Somerset UK
    Had a similar problem with my Jag which led to me cleaning and then replacing all sensors and wiring looms.
    To no avail and eventually sent the ABS pump ECU to this guy:
    ECUSOLUTIONSWALES Contact Us
    48hr turnaround and all now works as it should, cost was £99 plus £8 for a next day courier return.
    Unsure if he repairs Audi units though and it may be cheaper if you have the part no to buy a new or used unit from dealer/ebay?
  4. Re: ESP Sensor Unit G419
    Dec 2010
    Worcestershire
    Thanks both. Chris, any idea of location of both the ESP sensor (G419) and the Brake Electronics (J104) so I can check connections etc. cheers
  5. Re: ESP Sensor Unit G419
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi G419 is located under the centre consul. The unit must be secure but not over-stressed on the mounting pionts (10NM), and handle it carefully.
    J104 is the ABS hydraulic unit under the bonnet.
    I would only pull any connectors to check once the Ignition is OFF and wait a minute or two, this will stop any further fault codes showing up while checking the systems.
    Alan.
    VW T6 150 DSG Camper £££
    2 0 0
  6. Re: ESP Sensor Unit G419
    Sep 2011
    Lurking over a keyboard ...
  7. Re: ESP Sensor Unit G419
    Dec 2010
    Worcestershire
    Thanks for the advice and especially A6_Chris for the docs. Before I take the plunge and start ripping the car apart,has anyone else experienced this fault and successfully fixed it by swapping this sensor? Worried about it turning into one of those jobs where you go through a lot of pain and cost to swap one part only to find the fault was actually elsewhere....
  8. Re: ESP Sensor Unit G419
    Dec 2010
    Worcestershire
    Well, couldn't find a suitable 2nd hand sensor to try so had to go for a new one - ouch! Sensor was the bargain price of £540 plus vat and Auditechnik in Gloucester did the job in 1.5hours. Thoroughly recommend these chaps - helpful, friendly, and reasonably priced.
    3 0 0
  9. Re: ESP Sensor Unit G419
    Nov 2012
    Somerset UK
    Ouch that's painful!
  1. ESP, Crash sensor and other error lights.
    By zsharmask in forum VCDS - Help Requests
    Last Post: 13-03-2013, 08:04 PM
  2. Question ESP sensor causing issues
    By tufstfru in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2012, 04:06 PM
  3. ESP sensor position & part #
    By lescalder in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-03-2010, 10:46 PM
  4. Question esp - brake pressure sensor
    By stumpjumper in forum Leon
    Last Post: 23-10-2009, 10:10 AM
  5. Lateral ESP sensor
    By micky in forum Audi A3 - Archive Topics
    Last Post: 03-10-2007, 10:30 PM
