Thread: pioneer avic 9210bt
Results 1 to 10 of 19
  1. pioneer avic 9210bt
    May 2013
    northwich cheshire england
    hi, I have fitted a pioneer avic f9210bt into my Passat 06,everything works fine,but the bluetooth ,it shows firmware blank, when you press firmware update on the unit nothing happens have downloaded the update from pioneer,there update shows this file (avic20bt) did the update but nothing done to Bluetooth can anyone help.also when fitting I pulled the passage airbag plug out now the airbag light is on my dash thanks mike
  2. Re: pioneer avic 9210bt
    DSG4ME Guest
    Airbag needs a fault code clearer
    Get the FW on a flashdrive and usb load it
    1 1 0
  3. Re: pioneer avic 9210bt
    May 2013
    hi thanks,but forgive me whats a fw on flashdrive, were do I get the fw flashdrive from,when I get one do I plug it into the usb lead on the unit? mike
  4. Re: pioneer avic 9210bt
    May 2013
    hi can you point me to were I can get a fw flash drive thanks mike
  5. Re: pioneer avic 9210bt
    Mar 2008
    Just Cumbria now.
    What he's saying is, download the firmware update onto a usb flashdrive from your computer, plug the flashdrive into the head unit, then update the firmware.
    As to where to get one from Amazon, ebay, Pc World, Asda, Sainsburys.......you pays your money, etc.
    Nothing to see here, move along..
    1 1 0
  6. Re: pioneer avic 9210bt
    Sep 2008
    SE London
    FW = FirmWare = the data file you downloaded to flash update your headunit
    You can remove the radio surround from the air bag light by two clips that are at sides of bulb holder. That way the surround doesn't get in the way.
    Clear your current fault light with VCDS, or find someone local to do it for beer tokens
    Before I had VCDS did this. And it cost me a tenner to get it cleared. Thanks for this one VW!
    1 1 0
  7. Re: pioneer avic 9210bt
    May 2013
    ok thanks for that will give it a go
  8. Re: pioneer avic 9210bt
    May 2013
    hi, I just borrowed a flshdrive put the update on put into my unit nothing happened will this need to go back to pioneer thanks mike
  9. Re: pioneer avic 9210bt
    May 2013
    hi all,had some really good feedback about my pionner avic f9210bt,thanks to you all,but I have tried to update via sd card which update the unit to 200300 but the Bluetooth still isn't working been told to usb flashdrive, I put the update onto flashdrive but nothing happened still no Bluetooth just blank firmware no numbers can anyone help or do I need to send it to pioneer thanks mike
  10. Re: pioneer avic 9210bt
    DSG4ME Guest
    you may find the FW file if it's a Zip file needs to either come out of the folder the unzipped creates and then put on the media you are using, or you may have done that and it needs to remain in the folder,
    I would check the manual to see if it demands it loaded a particular way, you may find it will only load from a CD, also you should look in options for a link to update FW, it won't just do it by plugging in.
    1 1 0
  1. Pioneer AVIC F700BT in A3
    By ginner65 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-01-2012, 05:54 PM
  2. Pioneer avic bt900
    By pogocar123 in forum In Car Entertainment
    Last Post: 09-10-2011, 02:14 PM
  3. Pioneer AVIC-F910BT
    By blade4life1889 in forum Golf MK6 - 2009 - 2013
    Last Post: 27-08-2009, 02:13 PM
  4. Question Fitting a Pioneer Avic x1
    By djbilal in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2009, 10:57 AM
  5. Pioneer Avic-D3
    By golf08_parks in forum In Car Entertainment
    Last Post: 13-04-2008, 01:46 AM
