Thread: Rattling noise coming from front end over bumps.
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
  1. Re: Rattling noise coming from front end over bumps.
    #21
    May 2013
    Barnstaple
    Cheers guys. Ive priced them up and the actual drop links are under £20 so its no major issue. I'll get them changed regardless of whther it gets picked up in the MOT friday. It's a straight forward job by the looks of it. Its too much hassle to replace just the bushings
  2. Re: Rattling noise coming from front end over bumps.
    #22
    Sep 2011
    Lurking over a keyboard ...
    I had my ARB/C-Links/Drop links done after Audi advised them on a "health check" I had no noise to forewarn me of this ...
    @dealer IIRC the bill was £160 ish for C-links supplied fitted with a MOT and a puncture repair inc. a Q7 for a day ...
  3. Re: Rattling noise coming from front end over bumps.
    #23
    May 2013
    Barnstaple
    That's quite cheap for Audi to be fair. Some dealers tend to be more expensive than others for some reason. I had my dual mass clutch and flywheel done at the dealer last year and the bill came to £1200. They then picked up the following on the free health check:
    Rear pads and discs 70% worn: £280 ish
    Condensation in rear light cluster (common audi fault) £130
    Low brake fluid level (only because the pads were low) £50
    Wiper blades £60.
    Major Service £250 ish
    Cambelt almost due £580
    As I'm sure people are aware, the bill at Audi can spiral quite quickly. I'd rather do the majority of things myself as its about a 10th of the price. Obvious exceptions are the Cambelt etc
  4. Re: Rattling noise coming from front end over bumps.
    #24
    Oct 2013
    Aviemore
    Hi Steve did the drop links sort your problem, cos i think i got the same problem, dont want to put in garage if i can do it myself.
    Regards Sandis
  5. Re: Rattling noise coming from front end over bumps.
    #25
    May 2013
    Barnstaple
    Hi Sandis. It turned out to be a loose and damaged brake pad. The ARB drop links turned out to be fine
  6. Re: Rattling noise coming from front end over bumps.
    #26
    Oct 2013
    Aviemore
    Cheers Steve
    Wysłane z mojego GT-I9100 przy użyciu Tapatalka
  7. Re: Rattling noise coming from front end over bumps.
    #27
    Sep 2012
    Blackpool England
    I have this same noise / rattle that comes from the off side front only. The MOT tester couldn't find anything. It irritates the hell out of me. It's going in for a service on Monday and I've asked them to take a look. There first thought was the drop links, stating its a common problem and they've changed plenty over the last few years. I know it's not my brake pads as they were changed recently.
  8. Re: Rattling noise coming from front end over bumps.
    #28
    Oct 2013
    Aviemore
    Let me know how it goes please.
  9. Re: Rattling noise coming from front end over bumps.
    #29
    Jun 2013
    Notts
    Hi, mine are on the way out too, drivers side has been rattling for the last year and getting gradually worse, now the passenger side has started too. Nothing noticed on the MoT in June though. Loads of speed bumps round our way can't be helping.
    Anyone know the TPS price for genuine ones? ECP do Lemforder for about £23.00 each.
    Regards
    Tony
  10. Re: Rattling noise coming from front end over bumps.
    #30
    Sep 2012
    Blackpool England
    Just had a call from the garage. My service is done. The rattling noise has been investigated and diagnosed as the two arms at the bottom of the strut. Both need replacing due to play and movement in them which is causing the rattling. Been quoted £58 for each arm and approx an hour and a half labour.
    Has anyone had or heard of these faults before? The garage believe it to be fairly common with the floating suspension design of the A6.
    The near side is fine, only problems with the offside.
  1. noise from front end
    By scootir706 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2012, 08:47 PM
  2. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  3. Rattling noise coming from Alternator
    By macmillions in forum Golf MK2 - 1984 - 1992
    Last Post: 07-03-2011, 11:31 PM
  4. Rear end wandering on bumps
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 11:26 AM
  5. Front End Noise
    By 2musty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2008, 03:39 AM
