Thread: Rattling noise coming from front end over bumps.
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
  1. Re: Rattling noise coming from front end over bumps.
    Oct 2012
    United Kingdom
    12 Post(s)
    ARB drop links.
  2. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Cheers Gavin. I'll check them now. Have you had this problem before?
  3. Re: Rattling noise coming from front end over bumps.
    Nov 2012
    Somerset UK
    Suspension "C" Links are perished - Page 2
    I'd do it myself having seen how easy/quick it was.
    Also didn't throw out the alignment at all...so there was no charge when I got it checked.
  4. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Cheers mark. I'm not sure how to check if they're worn or damaged though. I've got my MOT Friday so I'd rather fix it beforehand rather than risk a failure
  5. Re: Rattling noise coming from front end over bumps.
    Nov 2012
    Somerset UK
    Personally I'd MOT first...since you usually have 10 working days to return for a free retest...but natch depends if your cars MOT will expire on Fri?
  6. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    The actual expiry date is the 22nd of next month so I'm fine on that side of things. I just want a definitive answer on whether its the bushes or the drop links themselves as knowing my luck, I'd replace both only to find out that it was t the cause if the rattle in the first place.
  7. Re: Rattling noise coming from front end over bumps.
    #17
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Steve_K View Post
    Over the past few weeks ive had a rattling noise come from under the front end of my A6. It only happens when i drive on rough or uneven roads. I thought it was the skid pan or wheel arch liners as there were screws missing so i ordered a new set and attached them over the weekend. The problem still persists unfortunately and after putting the front end up on axle stands and having a look, there doesnt seem to be anything loose or damaged. Has anyone had this issue before or have any idea what it may be? Thanks in advance
    I had a stone that had got into the spring cup, just behind the brake disk, that was rattling around.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  8. Re: Rattling noise coming from front end over bumps.
    #18
    May 2013
    Barnstaple
    Cheers Roy. I think it's looking more and more like my drop link though
  9. Re: Rattling noise coming from front end over bumps.
    #19
    Oct 2012
    United Kingdom
    12 Post(s)
    I Did after Audi changes them for an mot then they worked their way loose in a week or so.
    Yes they were apologetic.
  10. Re: Rattling noise coming from front end over bumps.
    #20
    Apr 2013
    Stirling
    11 Post(s)
    Quote Originally Posted by Gavin0478 View Post
    ARB drop links.
    I had a knocking noise also and it was the drop links! Sorted now... And no noise now... Fairy cheap fix and prob only a half hour job for both sides..
    Resident Curry Muncher
  1. noise from front end
    By scootir706 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2012, 08:47 PM
  2. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  3. Rattling noise coming from Alternator
    By macmillions in forum Golf MK2 - 1984 - 1992
    Last Post: 07-03-2011, 11:31 PM
  4. Rear end wandering on bumps
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 11:26 AM
  5. Front End Noise
    By 2musty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2008, 03:39 AM
