Thread: Rattling noise coming from front end over bumps.
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
  1. Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Over the past few weeks ive had a rattling noise come from under the front end of my A6. It only happens when i drive on rough or uneven roads. I thought it was the skid pan or wheel arch liners as there were screws missing so i ordered a new set and attached them over the weekend. The problem still persists unfortunately and after putting the front end up on axle stands and having a look, there doesnt seem to be anything loose or damaged. Has anyone had this issue before or have any idea what it may be? Thanks in advance
  2. Re: Rattling noise coming from front end over bumps.
    Aberdeen
    63 Post(s)
    I get the same so will be interested to see what you find. On my last A6 I ended up changing all the control arms and I am hoping this isn't the problem.
  3. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Yeah hopefully it isnt that. Thing is it doesnt happen over speed bumps so quite confident it isnt shock related. It just seems to be when there's dents and holes in the road. Sounds like something is loose
  4. Re: Rattling noise coming from front end over bumps.
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Steve_K View Post
    Could it be your heat shield ?
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  5. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Highly unlikely as I checked it when I replaced all the securing screws. It's tight as a drum
  6. Re: Rattling noise coming from front end over bumps.
    Nov 2012
    Somerset UK
    Any chance of anything trapped in your underbody shields...dropped tool/screwdriver bit/stone?
  7. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    I've just taken the heat shield off and there's nothing inbetween. I'm going to leave it off and go for a quick drive so that I can fully rule out the heat shield as the noise. I'll let you know. Cheers Mark
  8. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Nope it's definitely not the heat shield. The noise is exactly the same without the shield on. May be the bushes
  9. Re: Rattling noise coming from front end over bumps.
    Nov 2012
    Somerset UK
    By heat shield do you mean front undertray protector? What about the two side ones?
    Bushes don't usually just go, mine had an advisory for drop/C-link bushes perished for the last two MOT's no 'excessive play' and no noise whatsoever, but had them done a few weeks back.
    Can you identify the noise as metal on metal/plastic on metal? I know a little tricky as you can't be outside of the car when driven
  10. Re: Rattling noise coming from front end over bumps.
    May 2013
    Barnstaple
    Its definetley a metallic sound. I can feel some form of movement or vibration in the steering wheel when the noise happens. Yeah I meant the protective shield which covers the oil pan and front axle.
  1. noise from front end
    By scootir706 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2012, 08:47 PM
  2. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  3. Rattling noise coming from Alternator
    By macmillions in forum Golf MK2 - 1984 - 1992
    Last Post: 07-03-2011, 11:31 PM
  4. Rear end wandering on bumps
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 11:26 AM
  5. Front End Noise
    By 2musty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2008, 03:39 AM
