Thread: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
Results 1 to 9 of 9
  1. Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
    I had a blip on the power some time ago but it was after I'd let the tank get down to 15 miles or so from empty so I thought a bit of muck may have been sucked through from the tank. (The fuel filter was changed at the next service, 3k ago, for info)
    This cleared on it's own though and was forgotten but I noticed an occasional relapse with power fluctuating, often when just cruising so it felt like a bit of a judder.
    Today I hadn't got far and saw my first alarm of "Engine Fault, Workshop!" and the flashing heater coil symbol.
    I do a lot of short trips which I'm aware is not great for the DPF so I've just taken it down the motorway for a couple of junctions and back. The warning / flashing coil was on within half a mile even though all felt well.
    In case it's related to engine temperature I pulled over on the way back, turned off and back on again and the warning was back on again within a half mile. This time though I've acquired an engine symbol that's constantly on now.
    Any thoughts?
    Passat 2.0 TDI Sport 5dr Estate (170PS) 3C5 M6F CBBB (Sold 08/04/2019)
    Polo 1.2 TSI 77 kW (105PS) A05 6R1 4F2 (Mk5) M6F CBZB
    If you post for help please close the loop and post how you finally solved the problem.
  2. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Pembrokeshire
    22 Post(s)
    code read, thats what you need.
  3. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Tewkesbury, UK
    I've had the same thing on an 800 mile trip to France - not ideal! Had to pull over 3 times to switch off and back on, which cleared it each time. Bit worried about having to get all the way home...
    '56 B6 Passat Estate 2.0 TDi 140 SE with leather upholstery & sports pack
  4. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
    What was the fault in the end? Did you record the engine codes you had?
  5. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
    Also the engine light is actually an emissions control light.
  6. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
    OK, the fault code was 05215 which indicated the Air Mass Meter. Replacing this apparently brought up some other fault codes (not recorded) on the road test indicating the Throttle Body / Flap.
    From looking at youtube videos this sits nearly closed most of the time but mine was wedged wide open and didn't move. This was replaced and job done, Ł419 all in. That was a couple of weeks ago and all is well.
    I kept both components and looking at the manufacturer date on them they were both original parts.
  7. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
    Damn coil light came on a couple of times today, no engine light as of yet. ELM327 v1.5 purchased from ebay so will throw the codes onto here once I have retrieved them.
  8. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jan 2013
    Lahndon
    Quote Originally Posted by MHDxMK5BK View Post
    OK, the fault code was 05215 which indicated the Air Mass Meter. Replacing this apparently brought up some other fault codes (not recorded) on the road test indicating the Throttle Body actuator
    I had faulty throttle body actuator too, it threw few similar fault codes. Apparently some plastic teeth broke and cogs were stuck open which in turn threw few faults. Engine on start up and turn off vibrated rough too.
    In the end i ordered throttle body actuator on ebay at Ł159 and after part was replaced all was well.
    Passat B6 CR TDI, Bi-Xenon TRS FX-R retrofit.
  9. Re: Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    Jun 2012
    Peterborough, UK
  1. Please Help Flashing Engine Light & Constant Exhaust Warning Light
    By Tups1974 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-04-2012, 08:23 AM
  2. Please Help Engine hesitation and engine warning light
    By JIMMYAPPLE1977 in forum Alhambra
    Last Post: 17-09-2010, 11:52 AM
  3. Replies: 1
    Last Post: 08-02-2010, 12:34 AM
  4. Please Help "Engine Worksop" warning and flashing glowplug
    By Maffia_ in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2009, 04:58 PM
  5. Loss of power, flashing coil light
    By dazzaroon in forum Touran - Sharan - Caravelle
    Last Post: 13-03-2008, 10:37 PM
