Thread: Automatic Headlights ON - A6 C5?
Results 1 to 9 of 9
  1. Lightbulb Automatic Headlights ON - A6 C5?
    Apr 2013
    Netherlands
    Would A6 C5 support programming automatic turning on of headlights when engine is on?
    If so, can that be done with VCDS-Lite?
  2. Re: Automatic Headlights ON - A6 C5?
    46 Post(s)
    If you're talking about PRL (permanent running light) then yes it should be possible but sure if it works with Lite.
  3. Re: Automatic Headlights ON - A6 C5?
    There is no relays in the lighting circuit of a C5 so I doubt this can be done. It could be hard wired. Regards Peter
  4. Re: Automatic Headlights ON - A6 C5?
    Apr 2013
    Netherlands
    Personally to me, absence of relays gives some hope that it indeed can be done..
    But so far with the 'Lite' sw (unregistered) I have not succeeded to discover the controller which manages the lights. Perhaps need to invest into 'service manual' for c5..
  5. Re: Automatic Headlights ON - A6 C5?
    You are missing the point. The lighting circuit is directly wired ( No Relays ) on the C5 there is no lighting controller to allow any recoding.
    Regards Peter
  6. Re: Automatic Headlights ON - A6 C5?
    Mar 2008
    High Wycombe
    It can't be done in software.
    This could be done in hardware with an ignition switched live activating a relay.
    Or it could be done in fleshware by adding a subroutine after keystart to move the right hand 6 inches forward and 4 inches right, rotate switch 2 positions clockwise.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Automatic Headlights ON - A6 C5?
    Apr 2013
    Netherlands
    Quote Originally Posted by Peter D View Post
    Regards Peter
    yet, some form of 'control' exists - for when ignition is OFF, the high and the low beam bulbs are OFF as well, no matter what the switch position is..
  8. Re: Automatic Headlights ON - A6 C5?
    Mar 2008
    High Wycombe
    Quote Originally Posted by Normunds View Post
    I think that's just because the rotary switch is fed from the ignition live.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Automatic Headlights ON - A6 C5?
    To add, when you start the car the lights, radio, heater, etc etc also go out. There is a live feed to the ignition and when this is on it fees the lighing circuit via some fuses then finally to the lights themselves. And before you ask, the dim/main/flash stalk switches all the current again no relays involved. Regards Peter
  1. Automatic Headlights
    By PatMcCoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2011, 09:50 AM
  2. Are the headlights actually ON or OFF (in automatic mode)?
    By Piotro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-04-2011, 09:41 AM
  3. Automatic headlights aiming skwards
    By Y Pocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-01-2010, 01:08 PM
  4. Automatic headlights
    By JonBuoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-05-2009, 09:49 PM
  5. Automatic Headlights
    By AJA in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-05-2008, 07:45 PM
