Thread: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Question Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    May 2013
    middlesex
    Had this car since August 2012. Over the moon with it. Had it serviced by an independent garage last month. Despite resetting with a 'Snap-On' computer, the 'Service Due' indicator still shows on starting and engine switch-off. The independent (who I'd trust with my wallet, and has serviced my cars for 15 years), insists that he's following the correct procedure and his computer was only software upgraded a month ago.
    Emailing Audi UK was worse than useless - they gave me a procedure using dashboard buttons that doesn't work in my Audi and is for an older model. Spoke to their Customer Service who basically said I should use an Audi dealership for servicing (yeah, right), and refused to give me any help over the phone. They said they'd find out about this and I'd receive a callback - that's five days ago now....!
    Anyone got any ideas? Is it possible to do this on this model using dashboard controls or does it HAVE to be done by computer? If so, any pointers about the Snap-On machine I can pass on to my garage guy...? Cheers, Steve
  2. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    Sep 2011
    Lurking over a keyboard ...
    Hi ,
    Welcome to VWAF! ...
    AFAIK know there is no method using "dashboard" controls to reset service interval ...
    Just a meddling owner so no idea on the Snap-On machine but I know Zollaf has one Link:- VW AUDI Forum - VWAF
    Perhaps try a member off the VCDS map for a service reset Link:- VW AUDI Forum - VWAF
    As you have a low post count you can PM any of the mod team to PM members ...
    The Team Link:- A6_Chris , Eshrules, Mycarsavw
    There is another member who has/was having a similar issue on a facelift A6 Link:- DIS Service Due Reminder Won't Reset
    Does your MMI differ to DIS concerning the service rest? like in last post in above thread?
    2 1 0
  3. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    Jan 2011
    Stafford, UK
    Quote Originally Posted by marconiman View Post
    On my 2009 A6 I just :-
    On VCDS screen just click on SRI Reset
    Then choose the program that you want to follow, Done.
    I am set to 365 days.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
    1 1 0
  4. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    May 2013
    middlesex
    Quote Originally Posted by gupsterg View Post
    Hi ,
    Thanks for the welcome...!
    Apparently earlier A6's have a 'spanner' symbol on a button somewhere on the dash, and you use this in conjunction with the 0.0 trip reset button and turning ignition on to reset the Service Interval display...? Hasten to add this is what Audi say, and other forums, not me.... This is my first ever Audi, so still getting used to it...
  5. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    46 Post(s)
    I think you're thinking of the C5.
    Only the oil change can be reset via the CAR menu but everything else needs vcds or Audi diagnostic tools.
  6. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    Jan 2011
    Stafford, UK
    I have seen this on a C5 forum, C6 does not have this. VCDS only or Audi.
    You just piped me Chris.
  7. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    Apr 2013
    Bradford, England
    had this on mine when i went in for brake fluid at huddersfield audi. in vcds its instrument cluster then adaption and service reminder / interval, change from 1 to 0 and no more message BOOM!!!
    1 1 0
  8. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    46 Post(s)
    Yep Channel 02 in the SRI Menu - change the 1 to a 0 and job's a goodun
    1 1 0
  9. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    Aug 2007
    New Romney Kent
    Chris, not needed to do a SRI Reset for longer than I care to remember, I have just done this on SWMBO's 2010 TDi TT and the service due bong and spanner is still there! what am I doing wrong?
    The Operation I selected was:
    Flexible Oil Service Reset (LongLife/ Great Britain/Diesel),
    this is the log AFTER the reset:
    Sunday,17,November,2013,15:10:23:22041
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: License Plate: *** *** (2010 TDi TT)
    Mileage: 39926 Repair Order: POST SERVICE
    VCDS Release 12.12.0: SRI Reset
    Control Module Part Number: 8J0 920 980 R Labels: 8J0-920-xxx-17-MY8.clb
    Component:KOMBIINSTR. VDO H01 0590, Coding:0261409
    Operation: Please select an operation
    Channel Description Unit Current val. New val.
    02 Service Reminder Status 0 ---
    40 Distance since Service km x100 0 ---
    41 Time since Service Days 0 ---
    42 Minimum Distance to Service km x100 145 ---
    43 Maximum Distance to Service km x100 306 ---
    44 Maximum Time to Service Days 730 ---
    45 Oil Quality 2 ---
    47 Soot Quantity km x100 0 ---
    48 Thermal Load km x100 0 ---
    49 Minimum Time to Service Days 730 ---
    50 Basic Distance Value for Oil Change km x100 145 ---
    51 Basic Time Value for Oil Change Days 365 ---
    52 Basic Distance Value for Inspection km x100 310 ---
    53 Distance since Inspection km x100 325 ---
    54 Basic Time Value for Inspection Days 730 ---
    55 Time since Inspection Days 751 ---
    56 Day Counter Days 1207 ---
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  10. Re: Service Interval reset on 2010 A6 S-line 2.0 Diesel Avant?
    46 Post(s)
    Are you resetting Oil or Inspection?
    I think I remember Crasher saying its a pita resetting the SRI on the 8P chassis.
  1. How To Reset Service Interval.
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 21-03-2011, 06:09 PM
  2. can service interval be reset
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-06-2010, 07:04 PM
  3. Service interval reset.
    By euroslap in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2008, 06:51 AM
  4. Service Interval Reset
    By Seat Driver in forum Alhambra
    Last Post: 28-09-2008, 09:39 PM
  5. How To Reset Service interval
    By Photobloke in forum Bora - 1998 - 2005
    Last Post: 24-05-2008, 06:43 PM
