Thread: Smearing wiper? common issue?
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. Re: Smearing wiper? common issue?
    #21
    Jan 2013
    London
    Have posted my wiper issue on several threads but today had another fix from dealer.
    Another modified blade........but it actually looks really good so far.
    The obvious difference this time is a small 2" or so plastic strip under the fixing/pivot point.
    hopefully that's it. Dealer have been fantastic in trying to sort this including several visits from mobile tech.
  2. Re: Smearing wiper? common issue?
    #22
    Jul 2012
    Hampshire, UK
    Quote Originally Posted by kevlarpantz View Post
    Can you identify and share the part number on the blade, might help speed up the process of getting a decent replacement. Which dealer was it by the way?
    Mine - 2011 A7 3.0 TDi Quattro SE
    Hers - 2013 Mk7 Golf GT 1.4 DSG
  3. Smearing wiper? common issue?
    #23
    Feb 2013
    St Albans
    I have lived with the smearing issue since January and finally got sufficiently annoyed to buy these now that the weather is turning - VW GOLF VII 2012-Onwards HEYNER AEROFLAT WINDSCREEN WIPER BLADES 26"18": Amazon.co.uk: Car & Motorbike. Apparently they sort it all out, so fingers crossed. Delivery due any time soon. For me, not worth wasting time with the main <removed> me about cleaning the glass or other fob offs. Happy to give £18.99 to a company that has actually got off it's and designed some replacement wipers that are able to clear water off the windscreen.
    With regards to the above "Dealer have been fantastic in trying to sort this including several visits from mobile tech." I can't see what is fantastic about having to make several visits to your dealer before the windscreen wipers on a £20k car are able to wipe water off the windscreen properly, but then again I admit to being a grumpy sod who expects to live in a perfect universe.
  4. Re: Smearing wiper? common issue?
    #24
    Jan 2013
    London
    The code on the new blades is tiny but will try and get numbers if poss.
    Boost - The reason i praise the dealer is for NOT making me visit the dealership and sending out the mobile tech instead.
  5. Smearing wiper? 63 Plate GOlf GT TDI DSG 150 (Three Weeks Old )
    #25
    I have the same issue my drivers side wiper judders across windsceen and leaves a smear on the return wipe down, nothing on the blade or under the blade, been back to dealers and had new wiper fitted and wiper arm ajusted, but it still smears on return wipe, now dealer has ordered a new wiper arm and told me they will be in touch. I know a he wiper arm is not going to sort it,so i need a wiper blade that works can anyone please help or tell me where can i get a replacement for drivers side wiper blade ??
    Gary_99
  6. Re: Smearing wiper? common issue?
    #26
    Did the new windscreen wipers sort the smearing problem ? I am about to order the ones you listed in your last message..
    I have the same problem with my 63 plate golf gt tdi 150 !!
    Gary_99
  7. Re: Smearing wiper? common issue?
    #27
    Jul 2012
    Hampshire, UK
    Audi A7 driver's side blade works perfectly (see my earlier post in this thread)
  8. Re: Smearing wiper? common issue?
    #28
    Quote Originally Posted by jk88 View Post
    Has anyone managed to change the OEM wipers for Bosch Aerotwin ?
    The reason I ask is that I ordered a set from wiperblades.co.uk with the universal fit (including push button), but low and behold they don't fit ... Seems VW now use a narrower and shallower version of this type of fitting on the Mk7. WB very helpful and sent out another set of Aerotwins with a slightly different version of the push button, but these don't fit either. Keen to solve the problem, they then sent out a set of Lucal push button fit wipers, which are narrow enough, but, you've guessed it, not shallow enough (maybe just as well as Lucas don't do too well in any test I've seen). So back to the drawing board with WB.
    If anyone has managed to source some decent replacement wipers, I'd love to know what they are.
    Firstly thanks for getting back to me so soon, with your message about getting Audi A7 blades, i went to halfords this morning and managed to get a wiper that fits, got a set couldnt get a single wiper (Halfords Set143 Drivers side Flat Blade 650mm/26" Passenger Side Flat Blade 450mm/18") £29.99. I have tried it with screen wash and its not smearing, It will get a propper test tomorrow its going to rain i will let you know if i have any problems but it looks good.
    Gaz
  9. Re: Smearing wiper? common issue?
    #29
    Jun 2013
    Worksop, England
    Hi all, I am in the rather rare situation where I have had a 13 plate and a 63 plate mk7, the first I only had for a month before somebody decided that they would like one without paying for it. I have just received the second mk7 and can confirm that the first one was a pain in the backside for smearing right in my line of sight. The second one however has not / does not smear at all. There are a number of little things that are different to the 13 plate, mostly cosmetic / visual, and I can only assume that VW have acknowledged the wiper issue and resolved it.
  10. Re: Smearing wiper? common issue?
    #30
    Aug 2011
    manchester
    Quote Originally Posted by Leeconvery View Post
    What do you mean by little things that are different examples please if you would be so kind, thank you.
  1. Audi tt - Odometer issue - is it common?
    By Ben Buhagiar in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 07-04-2013, 09:21 AM
  2. Just how common is the porous head issue?
    By danb986 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-04-2011, 09:46 PM
  3. Front Spring Sheared - Common issue?
    By Rsjm5632 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2010, 10:36 PM
  4. The dreaded wiper issue
    By Dozz in forum Alhambra
    Last Post: 03-10-2009, 01:50 PM
  5. Is this common? A4 WIPER ARMS CORROSION
    By dkb18155 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2009, 10:24 PM
