Thread: Multifunction Steering Wheel Retrofit Help
Results 1 to 10 of 13
  1. Multifunction Steering Wheel Retrofit Help
    Dec 2006
    I am in the process of retrofitting a multifunction steering wheel to 2006 B7 A4. I have already purchased the following items:
    12 pin Slip Ring
    New Steering Wheel Controller
    Cruise Control Kit
    New Airbag Loom
    Where i am stuck is with the actual steering wheel itself. I have sourced one that came off an Audi S3. I have had advice from various people regarding the compatibility of this steering wheel for the A4. I have been told that it will fit by some, some have said it will fit but i will need to buy a new air bag for it and some have said that it won't fit at all. I am really confused and could really do with some help regarding this.
    The description and part no's for the steering wheel i have sourced are below (there is an airbag loom supplied with the steering wheel but i have already purchased one for the B7):
    "This is a genuine Audi S3 steering wheel, black leather with red stitching. The airbag is also included. You can find part numbers below but I believe the airbag loom is one of the most up to date ones so you shouldn't need to change it.
    The condition is absolutely amazing, there are no scratches or marks. It looks and feels completely new.
    Steering Wheel: 8P0 419 091 APVDG
    Alternatively, if i buy a multifunction steering wheel for a B7 Audi A4, could i use the existing airbag with it or would i still need to buy a new airbag?
    Any help would be greatly appreciated
  2. Re: Multifunction Steering Wheel Retrofit Help
    swindon uk
    Can you post a picture of your existing steering wheel?
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  3. Re: Multifunction Steering Wheel Retrofit Help
    Dec 2006
    Sure, i'll post a picture of it in the morning, its currently at the garage getting DRL's installed. Thanks for your reply
  4. Re: Multifunction Steering Wheel Retrofit Help
    Dec 2006
    Quote Originally Posted by ukdan View Post
    This is the existing steering wheel in the car with part no: 8E0 880 201 DG.
  5. Re: Multifunction Steering Wheel Retrofit Help
    swindon uk
    Im 99% sure your airbag will fit.
  6. Re: Multifunction Steering Wheel Retrofit Help
    Jan 2012
    Coding Something
    It will fit, all you will need to do is swap the airbag loom yellow connector over & make sure wiring suits, did another yesterday as it happens for a client, works fine.
  7. Re: Multifunction Steering Wheel Retrofit Help
    Dec 2006
    Quote Originally Posted by NHN View Post
    Is that if i buy a MFSW for a B7 and use the existing airbag or use the airbag on the wheel off the S3? Thanks
  8. Re: Multifunction Steering Wheel Retrofit Help
    Jan 2012
    Coding Something
    If you have the complete wheel then use that.
  9. Re: Multifunction Steering Wheel Retrofit Help
    Oct 2010
    London, England
    I can endorse this. I am that client!
    A4 3.0TDi SE Quattro Tiptronic in Quartz Grey.
    On order: S4 Black Edition Saloon in Tornado Grey with Fine Nappa black/silver leather.
    1 1 0
  10. Re: Multifunction Steering Wheel Retrofit Help
    Jan 2012
    Coding Something
    Why thank you Jeff & also thank you for such hospitality, you're a star
    Hope all working as you expected
  1. multifunction steering wheel
    By gareths quattro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2010, 08:35 PM
  2. Multifunction steering wheel?
    By fulcrum111 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-08-2009, 09:17 PM
  3. Multifunction Steering Wheel
    By rallye in forum Golf MK5 - 2004 - 2009
    Last Post: 17-04-2009, 05:27 PM
  4. Multifunction Steering Wheel
    By rallye in forum Jetta MK3 - 2005 - 2013
    Last Post: 21-04-2008, 09:41 PM
  5. Can I Retrofit a Multifunction Steering Wheel
    By Bilibong in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-04-2008, 10:39 PM
