Thread: Emissions Warning light
Results 1 to 9 of 9
  1. Emissions Warning light
    Dec 2010
    glasgow
    This morning got in the car, noticed that the engine emission light was on, its solid yellow and looks like an engine. Took it to a local garage (non-Audi) who very kindly reset the light for me. Their fault code reader said it was an exhaust gas pressure sensor fault. They advised to drive the car hard with high revs to clear out the dpf. So far the light has not come back on. Phoned Audi who said the light will come back on and a new part will be required.
    Car is a 2.0 tdi 59 plate, 40,000 miles.
    A6 C7 S line
  2. Re: Emissions Warning light
    46 Post(s)
    More than likely its a DPF pressure sensor, very common fault on the DPF model's.
    Get a full autoscan with VCDS if you can.
  3. Re: Emissions Warning light
    Apr 2013
    Bradford, England
    Agree with Chris here, its quite common - bloke who did my remap said a lot of his VAG customers have that fault. I've got a TDie and thats been mapped and DPF removed, mine now produces 184bhp and 420nm. Plus its even more economical now (if driven steady)
  4. Re: Emissions Warning light
    Dec 2010
    glasgow
    Quote Originally Posted by gribbo91 View Post
    That sounds great! Mine is also a 2.0 tdi e model in a state of de-tune to 136bhp. I would love to have DPF removed and remapped. Can you advise of cost and where to get it done?
    A6 C7 S line
  5. Re: Emissions Warning light
    Nov 2012
    Somerset UK
    Check the forums sponsors, or look in the tuning/remapping forum.
    I've a friend in Glasgow that's used these people for remap and DPF removal...albeit for a Beemer
    OMG Performance - DPF Removal - ECU Remapping - Contact Us
  6. Re: Emissions Warning light
    Apr 2013
    Bradford, England
    Quote Originally Posted by vwhighline View Post
    got mine done in Crewe by More-BHP.com for just over 400 squid. Jason knows his stuff, seems to get the most out of the VAG engines (did a lot of research before i got mine remapped). He specialises in VAG and dirty BMWs but hes a bit far from you!
  7. Re: Emissions Warning light
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Yep - a common fault. My 2009 had this issue - I have VCDS and reset the EML first time - the error reported was:
    4914 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal
    P2453 00 [032] - Lower Limit Exceeded
    5182 - Particulate Trap Bank 1: Efficiency Below Threshold
    P2002 00 [096] - Defective
    5262 - Exhaust Pressure Sensor 1 (G450): Signal too Low
    P0472 00 [040] - Defective
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 173
    Mileage: 75614 km
    Date: 2011.09.17
    Time: 10:25:58
    5162 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
    P0471 00 [096] - Open or Short to Plus
    Readiness: 0 1 0 0 0
    When the EML came back on, I took the car to the dealer and they replaced the G450 sensor which they said was faulty. My car was still under warranty at the time so I can't give you a cost estimate, sorry. It's not a big job - they did it while I waited.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  8. Re: Emissions Warning light
    Dec 2010
    glasgow
    Quote Originally Posted by MFGF View Post
    Freeze Frame:
    Fault Priority: 2
    Mileage: 75614 km
    Date: 2011.09.17
    Time: 10:25:58
    Cheers!
    MF.
    Thanks for all the advice, I've got it booked in to Audi next week. I'm just wondering if getting a Remap and DPF removed if the car would later fail on emissions testing at MOT?
    A6 C7 S line
  9. Re: Emissions Warning light
    Pembrokeshire
    22 Post(s)
    no. its a smoke test not an emissions test as such.
  1. Emissions Warning Light
    By rictic68 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-02-2012, 09:50 PM
  2. Emissions warning light
    By andyc12 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2009, 02:08 PM
  3. ABS Warning light, Emissions light, window.......
    By savs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2008, 03:06 PM
  4. Emissions warning light?
    By the stig in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-11-2007, 01:22 PM
  5. Emissions Warning Light
    By GrahamT in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-03-2007, 08:07 PM
