Thread: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Angry Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    Had an issue 3 times in just over a week where my 2007 B6 Passat won't start, it's a 2.0 170bhp diesel sport estate with 113k on the clock and a full dealer service history.
    I put the key in, wait a few seconds until the glow plug light goes off then start the engine. It starts then immediately cuts out, the dash makes a binging noise, the glow plug symbol starts to flash and engine workshop appears on the display.
    If I try and start the car immediately afterwards it won't even turn over.
    If I remove the key and wait 30-60 seconds and retry it starts first time (or it has the 3 times it's happened so far).
    I don't have vag-com so I can't check the error codes, I've read a few posts about a possible issue with the brake light switch? I've checked my brake lights and they are fully working.
    Any ideas before I take it in to the dealer?
    Volkswagen Tiguan 2.0 TDI SE NAV DSG 4motion 195bhp (Stage 1 remap)
    Sheffield, UK
  2. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    DSG4ME Guest
    Sounds like the ign key ecu fault tbh, brace yourself for a £350 repair.
  3. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    Quote Originally Posted by DSG4ME View Post
    Brilliant!
    Just had to move my car at work and it took 3 attempts to start. Started fine this morning before work though.
    I better get it taken in I guess.
    Sheffield, UK
  4. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    Just taken it in to a garage near work who uses our garage software, he's plugged it in for me and got the following
    05488 Unknown Component - Implausible Signal
    I've googled it back in the office as the garages internet was down and came across this - 17978/P1570/005488 - Ross-Tech Wiki
    It sounds the same as what I'm experiencing
    Possible Symptoms
    Engine starting but stalling immediately
    I did swap the key to the spare (brand new never used) about 6 weeks ago as the original wasn't opening the central locking (although it did unlock the boot and lock the doors and start the car), the problem I'm experiencing only started in the last week though so not sure if it's related.
    Any help appreciated.
    Sheffield, UK
  5. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    DSG4ME Guest
    It's not the key it's the contact surface inside the dash hole, some have managed to diy it but I wouldn't recommend it, VW dealers now replace the broken bits rather than the whole steering column and that brings the cost down from a Rio to about £350
  6. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    I've got someone hooking it up to VCDS/VAG-COM tomorrow to confirm my worst fears
    Many thanks for your input.
    Nick.
    Sheffield, UK
  7. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    DSG4ME Guest
    Quote Originally Posted by nick.king View Post
    Nick.
    Well keep fingers crossed that it's not that, it could be a couple of glow plugs gone down or the relay, if so the plugs are £23 each at GSF for NGK ones or £12 each for unbranded, the jist of things I've read says buy NGK ones, the relay is anything from £20 - £60 depending on if it's a eBay one or a dealer one, again I'd harbour on getting the real McCoy in this case, let us know anyway and lets hope it's the cheaper fix.
  8. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    VCDS Version: Release 805.0
    Data version: 20080529
    Thursday,23,May,2013,12:53:40:10074
    Chassis Type: 3C0
    Scan: 01 03 04 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8E047695 Mileage: 183100km/113773miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Not registered 0001
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 AS HW: 03G 906 018 AS
    Component: R4 2.0l PPD1.2 G 9971
    Revision: --H42--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00450 210 69121
    1 Fault Found:
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 37
    Mileage: 183066 km
    Time Indication: 0
    Date: 2013.05.22
    Time: 18:14:41
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 12.20 V
    Bin. Bits: 00011001
    Bin. Bits: 00000000
    Readiness: N/A
    Address 03: ABS Brakes Labels: None
    Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
    Component: J104 C4 440 V1 0003
    Revision: --020--- Serial number: 00000775802769
    Coding: 0001306
    Shop #: WSC 00722 210 72178
    No fault code found.
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 BT HW: 3C0 907 044 BT
    Component: ClimatronicPQ46 122 0707
    Revision: 00122021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000007317217
    Coding: F1880F0700041A00470A00000F00000000095D433200010000 0000000000
    Shop #: WSC 05124 000 00000
    Part No: 3C2 955 119 B
    Component: Wischer 090707 022 0601
    Coding: 00046997
    Shop #: WSC 05124
    Part No: 1K0 955 559 AB
    Component: RLS 170707 020 0105
    Coding: 00208933
    Shop #: WSC 05124
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 0C AIRBAG VW8 032 2522
    Revision: 12032000 Serial number: 003B1PDZ1H5P
    Coding: 0012355
    Shop #: WSC 05311 000 00000
    Address 16: Steering wheel Labels: 3C0-953-549.lbl
    Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
    Component: J0527 0015
    Revision: 00006000 Serial number: 3C9953507AE
    Coding: 0000114
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 971 HW: 3C0 920 971
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: V0007000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 42799 000 1048576
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P0771006E1
    Coding: F9807F060002022003
    Shop #: WSC 00722 210 89853
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 169682 km
    Time Indication: 0
    Date: 2012.08.24
    Time: 16:20:04
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    1 Fault Found:
    02811 - Control Module for Electronic Steering Column Lock (J764)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 45
    Mileage: 182660 km
    Time Indication: 0
    Date: 2013.05.15
    Time: 12:57:02
    Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
    Part No SW: 1T0 035 680 C HW: 1Z0 035 680 A
    Component: RNS-MID H04 2680
    Revision: AB001001 Serial number: ZZZZZZZZZZZZZZ
    Coding: 080004000400000200
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1132
    Revision: 32008001 Serial number: 00000129178709
    Coding: 0000693
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.135 H08 1901
    Shop #: WSC 02069 000 90108
    Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
    Component: KSG PQ46 ELV 042 0472
    Coding: 1991020051030E7630041C1D70085FCE107C40
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H07 9001
    Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1132
    Revision: 32008001 Serial number: 00000524878707
    Coding: 0000692
    Address 53: Parking Brake Labels: 5N0-907-801.lbl
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000088695
    Coding: 0000057
    Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
    Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1119
    Revision: 11006001 Serial number: 00000002036807
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1119
    Revision: 11006001 Serial number: 00000002041763
    Coding: 0000144
    Again any help advice much appreciated.
    Nick.
    Sheffield, UK
  9. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    DSG4ME Guest
    Two classic indications the steering column/key barrel is dying, all the other immobiliser faults are normal if this happens they will clear once the steering is fixed, it's default is to shut the car down when the code pops up.
    You may be able to try re-coding the keys but I think it will be the lock has gone dirty and tired.
  10. Re: Engine Workshop/Glow Plug Symbol Flashing/Car Won't Start
    Sheffield, UK
    Thanks again, is this the right way to re-code the keys?
    If your code is lost you will have to reprogram the fob. On the 2006 Passat, maybe the same on the 2007, you must pry the cover off of the manual key slot. Observe from the bottom there is a slot. Place the key in the slot, at the same time pry from the bottom and the whole cap will come off revealing the keyhole. With a good fob put power to the car but do not start the engine. With a manual key, lock the door. Now press the fob you are trying to train twice. It should take the code.
    Unlock the door, remove the good fob and test the new fob. It should work.,
    Sheffield, UK
  1. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
  2. Question Glow plug Symbol Flashing
    By adnw1965 in forum Touran - Sharan - Caravelle
    Last Post: 14-02-2011, 08:26 PM
  3. Please Help Flashing Glow Plug, Engine Workshop
    By belfast1888 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2009, 01:49 AM
  4. Glow plug symbol flashing?...
    By Niall76 in forum Bora - 1998 - 2005
    Last Post: 16-01-2009, 12:02 PM
  5. Flashing glow plug/coil symbol
    By Kel in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 01:54 PM
