Thread: A6 C6 Air Con issues
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
  1. A6 C6 Air Con issues
    Feb 2009
    Glasgow UK
    Well, after al the work I've done on my car recently, I thought I'd spend a few hours and get her cleaned up, washed, Poorboys Blackhole applied then covered with Natty's Blue paste wax..............she looks gorgeous.
    Unfortunately, I can't even post a pic or two as I'm so annoyed....lol ( Insert many & varied expletives for annoyed !! )
    Got in my car and took my son to drop his car off today............It was such a warm day, around 22c I put the AC on COLD & FULL BLAST only to receive a slow steady stream of warm air.
    Was hoping it may just need re gassed although I knew it probably wasn't likely.
    Took it to an Air con specialist who did a free check and said that the gas was fine, no issues there.
    Upon further inspection, he seems to think it looks like the following...
    Compressor has gone ( shaft snapped I think he said ) £394+vat
    High pressure sensor needs replaced £49.83+vat
    Labour to remove bumper, remove and refit compressor etc £120+vat
    Regas £40+vat
    I get the total to £724.59
    Wow - wasn't expecting this when I woke up this morning!!
    To be fair I suspected that something wasn't quite right for some time, it just didn't seem quite as cold, but other than that nothing I could put my finger on
    Going to head off to do a little research...............Any useful / helpful comments appreciated as always
  2. Re: A6 C6 Air Con issues
    Mar 2009
    Essex
    OUCH!!
    Sorry to hear this Jim, especially after you've been battling for so long to get your other isues sorted! What a bar steward.
    And it looks as if those weren't even main dealer prices....? Gotta be worth a second opinion somewhere?
    (And your temp has been about 7 deg C warmer than down here today. Tried to work at home with no heating on. My feet are like icicles. )
    1 1 0
  3. Re: A6 C6 Air Con issues
    Jun 2006
    Hey Jim,
    Sorry to hear you are having problems and facing shelling out more money.
    As always I'd recommend shopping around, not only for a 2nd opinion but also prices. If the shaft has gone, would you not be able to see it? Could that part be fixed somehow, say new shaft made up/welded? Just a thought.
    If you are looking at new parts, try and get the part numbers then it's easier to widen the search on those specifically.
    Good luck and keep us posted.
    Final thought, with the weather in the UK at least you don't have to get it fixed in a hurry !
    ATB
    Andy
    1 2 0
  4. Re: A6 C6 Air Con issues
    Feb 2009
    Glasgow UK
    Thanks for the kind words Gonzo / Andy.
    You're right, thats not main dealer prices, I need to contact them to see what they have to say about it.
    Probably around £1200 I'd guess, hopefully they'll fix it for free....lol
    Willdo on the shopping around part Andy, as always...........
    Why is there so much month left at the end of the money??
  5. Re: A6 C6 Air Con issues
    Apr 2013
    Stirling
    11 Post(s)
    Gutted for you Jim... I'd definitely get a 2nd opinion on it though! Maybe ring Audi Technik and A 4 Audi for any AC recommended dealer's?! Need a hand give me a shout...
    Resident Curry Muncher
    1 1 0
  6. Re: A6 C6 Air Con issues
    Jun 2006
    Hey Jim,
    Another thought (hence the smell of burning !!) could it be the clutch on the compressor that is faulty? Also a quick look on fleabay shows many new ones for around £230 so worthwhile knowing exactly what you are after. Good chance you can get the initial estimate down a bit.
    2 1 0
  7. Re: A6 C6 Air Con issues
    Feb 2009
    Glasgow UK
    Cheers Aly...........my flabber was well n truly gasted today...lol
    Totally underwhelmed by it all
    I'm beginning to wonder what she'd be like if I didn't look after her??
  8. Re: A6 C6 Air Con issues
    Feb 2009
    Glasgow UK
    A quick look through the internet seems like there is multiple issues here and a known fault too?
    link
    link1
    link2
    link3
  9. Re: A6 C6 Air Con issues
    Leicestershire
    How about starting with a vcds scan and output tests?
    I've just changed my a/c pressure sensor today and anyone that tells you it can be done with the bumper on must have fingers like an aye-aye.
    Anyways I done it with bumper in place with normal fat fingers, alot swearing, and grazed bruised hands. i had to move a lot of crap out the way and to be honest it would have been easier to take the bumper off. I cleared the fault code and it's not registering as faulty anymore - checked a/c pressure and it's only 2bar so will regas it tomorrow.
    I would get a fault scan done the most common fault for these is the pressure sensor/regas.
    The o-rings are a weak point and deteriorate through lack of circulating lubricant I.e. long periods of inactivity. Causing gas to leak too.
    I'm hoping a regas sorts mine out if not as mentioned next in line would be clutch plate in compressor.
    Good luck!!
    Audi A6 C6/4F 3.0 V6 TDI Quattro S-line - BMK
    2 1 0
  10. Re: A6 C6 Air Con issues
    Jun 2008
    Dunfermline
    Hi Jim I have had 2 compressors rebuilt over the years via the garage I use in Bonnybridge. The guy completely strips and re-builds them using new seals etc and they have always worked faultlessly afterwards. I didn't deal with the guy directly therefore can't tell you his name, but if you speak to Duncan at Hypertech (01324 812212) he will put you in touch. Tell him Richard Temple put you in touch. Hope this helps. Cheers
    3 2 0
  1. 1999 Audi A4 Air Con issues
    By neilhewett in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-09-2013, 10:08 AM
  2. Air Con issues
    By b1nuzz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-11-2012, 04:59 PM
  3. Please Help Issues following air con re-gassing
    By Jones the Horse in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 10:06 AM
  4. Air Con Issues - driving me nuts
    By diesel-a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2008, 07:09 PM
  5. Air Con issues
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 12:10 PM
