Thread: A-6 /Wet floor
  1. Re: A-6 /Wet floor
    Sep 2007
    my had the same problem ,however the local garage suggested it was a leak pipe from the colling ssystem and got it changed,it did the job for me however it could be a different situation
  2. Re: A-6 /Wet floor
    Oct 2007
    I have recently had the same problem the cause was a blocked drain plug located under the battery after heavy rain this created a flood of water whos only means of getting out of the channel was to come through the pollen filter and fan. This resulted in a cost of £360 as it damaged the convenience unit on the passenger side.I am pursuing costs for the repair as I as many others do think it is a design problem. Will keep you posted on my success.
  3. Re: A-6 /Wet floor
    Cheshire, or my A6
    I heard from a friend there was a recall and some pre 2003 A6's. Mine is a 53 plate, so touch wood I won't get a problem, but Audi had supposedly sorted it out for Sept 2003 cars onwards. I am amazed they still have not sorted it on a 2006 model!!!
    Paul
  4. Question Re: A-6 /Wet floor
    Aug 2007
    I too have had this problem 54 A6 SE 2.4 thus costing £360 for a light relay unit.
    Now my parking aid is flashing as a malfunction. Took it in but would not respond to diagnostic connection. What next? Thinking of getting shot only had it for 2 months.
    michelle
  1. Wet floor
    By L90OOK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2007, 11:14 PM
  2. A4 B7 Floor Mats
    By jum1000k in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2007, 09:41 AM
  3. Golf Mk5 Floor Mat Twists
    By BrentNewbury in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2007, 11:38 PM
  4. MPG's fell through the floor!
    By Cam in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-04-2007, 08:21 AM
  5. Removing carpet to dry out the floor...
    By AsaTDi in forum Passat - Archive Topics
    Last Post: 16-12-2006, 02:44 PM
