Thread: What size Discs has a Standard 1.8T got?
Results 1 to 10 of 17
  1. What size Discs has a Standard 1.8T got?
    Aug 2011
    Hornchurch
    Want to do Discs and Pads on my car, what size Discs do they have? I've seen some really nice 312mm drilled & grooved discs on fleabay
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  2. Re: What size Discs has a Standard 1.8T got?
    May 2008
    Sam It will say in the options list. 1st page of your service book. Can get all the options decoded online and this will tell you. That's how I done mine. Mine are 312mm and option code was 1LT.
    Hope this helps
    Mark
  3. Re: What size Discs has a Standard 1.8T got?
    132 Post(s)
    1979 Post(s)
    yes you need to know your PR code 1LB, 1LE (288) or 1LT, 1LF (312)
  4. Re: What size Discs has a Standard 1.8T got?
    Aug 2011
    Hornchurch
    Brilliant. Thank you.
  5. Re: What size Discs has a Standard 1.8T got?
    Aug 2011
    Hornchurch
    ive got 288mm disks.
    If I want to put 312's on it, what do I need to change?
    Is it just the Carriers & Dust shield or do the calipers need changing too?
  6. Re: What size Discs has a Standard 1.8T got?
    Aug 2011
    Hornchurch
    Next Question.
    The advert on fleabay about the cariers i'm looking at says they are for ATE calipers and not Lucas. is there a quick way to know what calipers I have? or is it a wheel off and look for Manufacturer markings job?
  7. Re: What size Discs has a Standard 1.8T got?
    132 Post(s)
    1979 Post(s)
    280 are Lucas/Girling, 288>345 are ATE. Part number wise 288 and 312 calipers are different but in my experience those from a 288 can be used on 312 discs and carriers.
  8. Re: What size Discs has a Standard 1.8T got?
    May 2012
    Durham
    From what I found searching the web was 3.0l petrol a4 carriers needed and 312mm discs think part number for the carriers is 4B0615125C but would check to make sure
  9. Re: What size Discs has a Standard 1.8T got?
    132 Post(s)
    1979 Post(s)
    I get the same part number, about £110 each from Audi.
  10. Re: What size Discs has a Standard 1.8T got?
    Aug 2011
    Hornchurch
    Cheers crasher. Is that stamped on the Caliper or will that be on my Equipment list? Also, Are the front and rear Discs different? there are 2 sets of Drilled & Vented 312mm Discs on ebay at really good prices so didn't know if I should bid on both sets or just one and then find some rears to match.
    Andrew555_123, Yes the 3.0 petrol has the 312mm discs and those are the carriers I need to get. I can get them from ebay for £40 each side so I think that is what I am going to do.
    I'm then going to paint my Calipers and the hub on the Disks a nice Gloss Black (a bit like an S4 but without the S4 logo) just to finish them off. I did want red Calipers but I think they look a bit cheap when done to the Standard Calipers, they really need to be big 6 Pots if you are going to make them stand out.
  1. high performance discs vs standard
    By hongkongstuey in forum Chat - Anything with wheels
    Last Post: 13-02-2009, 12:49 AM
  2. Question What size brake discs????
    By pedropete27 in forum Bora - 1998 - 2005
    Last Post: 11-02-2009, 03:00 PM
  3. what size discs
    By scrappy77 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2008, 10:23 PM
  4. Standard door Speaker Size!
    By psun69 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-11-2007, 07:35 PM
  5. What size discs do I have?
    By chrisvrscrx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 08:53 PM
