Thread: advice on touran 2.0 tdi engine
Results 1 to 8 of 8
  1. advice on touran 2.0 tdi engine
    May 2013
    oxfordshire
    hi guys,
    looking at multipole cars at the min, but one is a touran 2.0 tdi sport.
    do these have common faults i need to be aware of like the balance shaft / oil pump issue?
    thanks
  2. Re: advice on touran 2.0 tdi engine
    46 Post(s)
    Depends on the year and or engine code of the car.
  3. Re: advice on touran 2.0 tdi engine
    May 2013
    oxfordshire
    hi, not sure on engine code but its 04 plate
  4. Re: advice on touran 2.0 tdi engine
    Jan 2009
    towcester northants
    oil pump issues were sorted 58 plate onwards
  5. Re: advice on touran 2.0 tdi engine
    May 2013
    oxfordshire
    so this is still going to have oil pump issue?
    http://www.autotrader.co.uk/classifi...true?logcode=p
  6. Re: advice on touran 2.0 tdi engine
    133 Post(s)
    1988 Post(s)
    The BKD engine has a conventional oil pump and no balancer shaft system and does not suffer from oil pump failure issues, I can't understand where people get the idea that the Golf 5 and Touran are subject to this issue as the Passat is, they are different engines.
  7. Re: advice on touran 2.0 tdi engine
    Aug 2008
    Flitwick, Beds
    I can. When almost every mainstream model in the VW and Audi ranges has a 2.0 tdi version, most of us would quite easily assume they're all the same engine, or at least all based on the same engine. Which I suspect in truth they are.
    If the troubles are only linked to components that relate to the differences between them, then of course confusion will reign trying to suss which has or hasn't got the faulty component or not.
    Knowing your engine code is obviously essential. But I'd guess that as time moves on, other engine codes could develop the same or similar faults and end up added to the list. The list of passats suffering injector problems is pretty long, but I doubt they all suffered the fault at the same time.
  8. Re: advice on touran 2.0 tdi engine
    133 Post(s)
    1988 Post(s)
    Well at least it isn't as difficult to get your head around as it was trying to work out which Austin/MG C series engine is which! I suppose they are all EA827 series units but there are 8 and 16 v units and 16v PD and CR units and about the only thing that connects them all is the 88-mm bore centre spacing, there are multiple and huge variations and many parts are not interchangeable at least without modification.
  1. Advice needed on buying 140 tdi touran
    By delh82 in forum Touran - Sharan - Caravelle
    Last Post: 24-08-2012, 09:39 PM
  2. 2.0 TDI Engine advice (170bhp)
    By Agent_Trig in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-02-2011, 10:18 PM
  3. Please Help 115 tdi pd engine blown, advice please on replacement engine.
    By glyndwr1998 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 01:37 PM
  4. Buying Advice - Touran TDi
    By pumbaa in forum Touran - Sharan - Caravelle
    Last Post: 18-11-2009, 08:37 PM
  5. Advice on the 2.0 TDI engine please
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-10-2009, 07:48 PM
