Thread: Sqeaky front Suspension
  1. Sqeaky front Suspension
    Jun 2009
    Telford UK
    Hi All
    Should the upper suspension arms entering the strut with the pinch bolt be greased or bone dry
    I Have a terrible squeaking sound from when I move the steering and when bouncing the corner of the car
    Last night I removed the pinch bolt and moved the steering and bounced the corner of the car and all was fine
    So removed the 2 arms and greased up the pins and re inserted and thought everything was OK until this morning
    Arms are on 12 months old and felt smooth
    On thinking about it why would there be a pinch bolt in the are of greased up pins ??
    The other side was replaced the same time and all is fine over there
    Any thoughts please
    I Thinking of stripping and removing all the grease
  2. Re: Sqeaky front Suspension
    grease would of been used to stop the long bolt seizing in , cos they do seize in .... there is a chance whoever fitted the arms tightened them up without having the weight of the car on the wheels. ????????????
  3. Re: Sqeaky front Suspension
    Jun 2009
    Telford UK
    Hi
    It was me who fitted the arms and all done with weight on as my previous local VW garage did it all without weight and look at me blank when I try to explain why
    So do you think I should strip and remove all the grease from the 2 pins and holes now and try again...
    Thanks in advance
  4. Re: Sqeaky front Suspension
    noises are hard to diagnose , im sure youd agree , just keep at it and youll find whats causing it . im surprised someone hasn't said scan for fault codes
  5. Re: Sqeaky front Suspension
    Jun 2009
    Telford UK
    That made me laugh ... But I know what you mean
  6. Re: Sqeaky front Suspension
    Jan 2011
    Bishops Stortford UK
    Hi,have you checked the anti-roll bar bushes yet?Also the lower rear control arms bushes squeak when worn or perished especially when the weather gets warmer because the bushes dry out and start being noisy.Hope that helps!
  1. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  2. Question Mk3 Golf Front Suspension Leg removal & front wheel bearing change
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-02-2010, 12:21 PM
  3. sqeaky rear suspension
    By tony dale in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2009, 07:22 PM
  4. Please Help Sqeaky Noise!
    By VW_GTTDI in forum Golf MK5 - 2004 - 2009
    Last Post: 09-06-2009, 09:51 PM
  5. sqeaky brakes
    By danger mouse in forum Touran - Sharan - Caravelle
    Last Post: 06-02-2008, 06:56 PM
