Thread: Excess movement in steering column
  1. Excess movement in steering column
    zak Guest
    Hi there,
    I'm a newbie to this forum, so please bear with me if I'm not too clear on any matter. I have a vw passat tdi 1.9 diesel n reg. The problem I have is that the steering wheel moves excessivly up and down by about 1.5cm. The steering column has the capability of being adjusted. This movement is still there even when the steering column has been locked in place. Does anyone have any ideas what needs to be replaced?
    Thanks in advance.
    Regards,
    Zak
    Jan 2006
    Nottingham
    Most steering columns have an upper bush where the column passae thru the support bracket bolted to the bulkhead. When this bush is worn it allows the steering wheel to move up and down excessively
    Its a Volkswagen. I'll drink to that
    zak Guest
    Thanks for your reply glynnd. Would you by any chance have a schematic diagram of the steering column for the passat model specified above?
    Jan 2006
    Nottingham
    I think I might have one. I will try and post it on the thread later 2nite
    Glynn
  1. Steering noise
    By Mav2006 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-12-2007, 03:37 PM
  2. excess revving at start up and smoke
    By kevin123 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2007, 01:29 PM
  3. excess vibration on a tdi vento
    By vwnige in forum Vento - 1994 - 1998
    Last Post: 07-05-2007, 01:45 PM
  4. MK3 Steering Column Help
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 06:46 PM
  5. mk3 steering problem
    By Maddoggolfface in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-11-2006, 08:24 PM
