Thread: Audi health check
Results 1 to 10 of 18
  1. Audi health check results OMG
    Apr 2013
    West Midlands uk
    Just looked at my Audi health check report from Thursday,
    fault in memory regarding intake manifold bank 2 ref tpi 2016504/22 requires both intake manifolds
    any idea what this kind of fault would have an effect on the car! £1379.50 to fix
    also
    fault in memory glow plugs cylinder 1 open circuit?
    and my n/s/f-o/s/f rear suspension arms are non genuine should I be worried?
    gearbox under tray missing
    Headlight washer jets nozzles missing? How would I get to see what exactly is missing? I take it that these need replacing for £148.53 I defo need these
    boot tail gate struts a bit week, when I close my tailgate with the button on the tailgate. The tailgate slams then locks, the newer cars gently shut then lock. Is this how mine should close? Or is this just the difference in 6yrs of progress
    chip
  2. Re: Audi health check results OMG
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Chipsteruk View Post
    The manifolds can have just the wear on the Links:- Audi V6 TDi 2.7 & 3.0 Inlet Manifold, Swirl Flap Repair Kit.
    The motors can also go up the swan ... a VCDS scan/fault log would help ...
    Another thing to read, note the dates of posts as at that time swirl link repair kit was not known ... Link:- Swirl flaps - are they worth it?
    Next here is Sparkers "How to..." Link:- VW AUDI Forum - VWAF
    Faulty glow plug ... Link:- Which Glow Plugs for 3.0TDI (BMK)
    No idea ... if my car I wouldn't worry too much if I'm not having any problems with it ...
    I got one of these for mine ... Link:- AUDI A6 GEARBOX UNDERTRAY UNDER COVER SHIELD 150114 | eBay
    I'll check on pricing of parts ... but bumper off job to replace from my understanding ... Link:- VW AUDI Forum - VWAF
    IIRC there is a software update/recall on power tailgate ...
    Technical background
    On Audi A6 Avant vehicles manufactured within a specific period it is possible in rare isolated cases that the power-operated tailgate can close again abruptly and unexpectedly after it has been opened using the power function.
    Remedy
    On the vehicles affected, a software update of the tailgate drive must be carried out. The new software incorporates an optimised close function. An increased resistance (slight shaking) will be felt when closing the tailgate by hand. The automatic close function remains unchanged.
    I'd ask at dealer if this apply to you before getting any other work done...
    1 3 0
  3. Re: Audi health check results OMG
    Apr 2013
    West Midlands uk
    Quote Originally Posted by gupsterg View Post
    Hi Gups,
    Thanks for taking the time to reply have you done the above method? as my banks are supposed to be covered by the warranty, but if its not the method above might come in handy
  4. Re: Audi health check results OMG
    Sep 2011
    No, mine are the factory fitted original manifolds/links/motors from markings of P/N & date codes ...
    I have the swirl link kits as thought be handy to have in the garage ...
    Soon removing manifolds, etc to do some EGR cleaning/component renewal work Link:- Audi A6 2.7 & 3.0 TDi EGR & Intake system cleaning info please...
  5. Re: Audi health check results OMG
    Apr 2013
    West Midlands uk
    Gups what are the part numbers on your tailgate struts? mine are a 4F9827552A
  6. Re: Audi health check results OMG
    Sep 2011
    Mine is not power tailgate so different P/N ...
    Pages 12, 13, 14 apply to A6 MY2008 and below ... Link:- Power Tailgate A4 A6 A8 Q5 Q7 PDF
    Series production:
    There are new, modified gas struts to eradicate this problem.
    A6 Avant: lift power increased from 550 N to 600 N. From June 2008, vehicle no. 4F78N136511
    Action:
    A6 Avant:
    Install two new gas struts, part number 4F9 827 552 E with increased lift power.
    So you have TSB for software update in post 2 & improved struts from MY2008 onwards highlighted in above linked doc ...
    What year is your A6? I'm guessing lower the 2008 as you would have improved part already but higher then 2006 due to what road tax you stated you pay in another thread ...
  7. Re: Audi health check results OMG
    Apr 2013
    West Midlands uk
    i dont think i need a software update, i just need some new struts My car is a 57 plate.. i was going to just get some of the same but now you've given me more info maybe i will check out the other part numbers
  8. Re: Audi health check results OMG
    Feb 2009
    Glasgow UK
    Now thats what I call a reply!!
    Great info Gup
    Good luck Chipster and hope to hear all is well
    1 1 0
  9. Re: Audi health check results OMG
    Apr 2013
    West Midlands uk
    Jim my A6 experience is going from bad to worse! I'm really starting to appreciate not having all the gizmos on a car
    gups you know my error code found on my intake manifold? Would this throw up an error on the dash? Because I don't have any engine management lights on?
  10. Re: Audi health check results OMG
    Sep 2011
    From all that I have read you should see below MIL light on ins.cluster if swirl flaps/motors had a fault ...
    Perhaps get a member to scan your car with VCDS Link:- VWAF User Location Map - VCDS - Google Maps
    Via "output test" in module 1 you can make swirl flap motors run without engine on to test operation ...
    You can also observe MVB's in module 1 concerning their operation ...
    Quote Originally Posted by a8 tech View Post
    036 Intake manifold flap bank 1
    1) Engine speed
    At idle: 720 ... 820 rpm
    2) Intake manifold flaps bank 1 specification
    At idle: 19 ... 81 %
    3) Intake manifold flaps bank 1 actual value
    4) Actual air mass
    [mg/stroke]
    Permissible difference between specified and actual value at
    Idle: maximum +/- 2 %
    037 Intake manifold flap bank 2
    1) Engine speed
    2) Intake manifold flaps bank 2 specification
    3) Intake manifold flaps bank 2 actual value
    4) Actual air mass
    [mg/stroke]
    Extract from Link:- audi 3.0tdi engine measurement blocks
  1. HEALTH CHECK graphs does not match
    By navicx in forum VCDS - Help Requests
    Last Post: 20-11-2012, 11:59 PM
  2. My Health Check - Result!
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2011, 05:17 PM
  3. Free Audi Health Check?
    By oceanscape in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-09-2010, 08:25 AM
  4. Audi - free health check?
    By oceanscape in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 30-08-2010, 04:35 PM
