Thread: struggling with AMI part numbers
Page 1 of 3 123 LastLast
Results 1 to 10 of 65
  1. struggling with AMI part numbers
    Dec 2008
    manchester, UK
    Hi guys,
    I know there's loads of posts already about AMI but I'm struggling to work out the part numbers I need.
    According to the car data print out from Audi I have "7T2 Nav Low" ""8DP Radio Low II" and "7A6 CD player/Changer".
    In the glove box I have a dvd drive with two sd card slots and a cd changer.
    I want to replace the CD changer with an AMI.
    I take it I don't need optical bridge cables?
    Will I need vag-com?
    and what is the part no for the AMI that will just slot in?
    any help greatly aprreciated
  2. Re: struggling with AMI part numbers
    Nov 2009
    46 Post(s)
    If you have MMI High (Large colour screen) above the centre airvents AMI will work, you may need to update your FW version.
    If you have Basic or Basic+ AMI cannot be fitted
    AMI will be a straight swap with the CD changer if you have High and your FW is new enough.
    That is me guessing you have a pre-facelift car.
    Facelift cars are different, you need activation with Audi.
  3. Re: struggling with AMI part numbers
    Dec 2008
    manchester, UK
    thanks for the quick reply.
    I don't think it's MMI high as the nav is DVD based.
    I don't know what you mean by basic or basic+?
    I have a face lift car.
  4. Re: struggling with AMI part numbers
    Nov 2009
    46 Post(s)
    See above
  5. Re: struggling with AMI part numbers
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by revver View Post
    You have MMI 3G ...
  6. Re: struggling with AMI part numbers
    Nov 2009
    46 Post(s)
    Oops - reading too quick!
    Quote Originally Posted by gupsterg View Post
    You have MMI 3G ...
    On that note, AMI is wired directly into the 5F unit. Jon said it's easy but I'm pretty sure you need some sort of activation dongle/update from Audi to enable the feature.
    You can keep your changer as AMI is located on the roof of the glovebox and only the port is showing, unlike the 2G where its a seperate box.
  7. Re: struggling with AMI part numbers
    Dec 2008
    manchester, UK
    sorry Chris, what's a "5f" unit?
  8. Re: struggling with AMI part numbers
    Nov 2009
    46 Post(s)
    I (think) its like the central hub where all your entertainment features live and where your MMI features work from.
    A handy thread would be to look here ipod confusion audi models
    Jon covered most models from memory on that thread, also look at his started threads as he's commented on it in the past.
  9. Re: struggling with AMI part numbers
    Dec 2008
    manchester, UK
    i've just seen Audi A6 AMI retrofit - YouTube which has the same setup as my car, so it can be done if I had the part numbers.......
  10. Re: struggling with AMI part numbers
    Jan 2011
    Stafford, UK
    Anything here any good ? - AMI (Audi Music Interface) part numbers / Notes on retrofitting AMI (A4/A5/A6) (by LoCal) - Audi A6 Q7 A8 A4 A5 Retrofit Jälkiasennus Nachrüsten Retro-fit
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  1. Part Numbers
    By KSD in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2013, 11:49 AM
  2. Who knows their part numbers??
    By type49 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2010, 11:38 PM
  3. part numbers??
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 07-09-2009, 01:47 PM
  4. VW Part Numbers
    By vwmark in forum Chat - Anything with wheels
    Last Post: 19-03-2007, 03:09 PM
