Thread: struggling with AMI part numbers
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
  1. Re: struggling with AMI part numbers
    #41
    Dec 2008
    manchester, UK
    Quote Originally Posted by gupsterg View Post
    Thanks for that Roy ...
    We now need revver's info once he has a scan ...
    I'm being cautious with information as I do not wish anyone to have any issues from meddling ...
    I have misinterpreted this section of A8 Tech's instructions ...
    What it means is that if you do the AMI MMI 3G retrofit DIY @ home when you go for a dealer software update which is MMI related it will be undone and you will need to recode it again ...
    This occurs due to how when car is plugged into VAS and communication occurs between it and VAG server it will recode car to what it had out of factory, ie no AMI ...
    Unless you get Audi to fit it?
  2. Re: struggling with AMI part numbers
    #42
    Sep 2011
    Lurking over a keyboard ...
    If you get Audi to fit it the fitting dealer needs to update the server to include AMI to car data ...
    The info for the retrofit @ the time posted by A8 Tech highlighted dealers were not aware of this retrofit ...
    If they are now I have no idea and if they will update car data on server for you ...
  3. Re: struggling with AMI part numbers
    #43
    Dec 2008
    manchester, UK
    In terms of installation for either of the part numbers we found I guess they're the same as the kufatec ones (http://pdf.ampire.de/kufatec/36739-2_englisch.pdf)
    1 1 0
  4. Re: struggling with AMI part numbers
    #44
    Dec 2008
    manchester, UK
    The eBay item Chris posted the link to earlier has part number 4f0051960 and is being sold by an Audi dealer.
  5. Re: struggling with AMI part numbers
    #45
    Sep 2011
    Quote Originally Posted by revver View Post
    Great post ... the dongle they provide is enabling the green/service menu (which VCDS can do) then rest is same as A8 Tech's instructions ...
    I will check that tomorrow for you ...
    Some more info for you Link:- Mmi 3g ami activation/retro fit done
    Quote Originally Posted by a8 tech View Post
    No part numbers due to recent ebay sellers, but its done and I will not be doing a "how to"
    A8 Tech & others work really hard IMO to provide or give this info and others rip their work off for their own gains, I know I for one appreciate their work A8 Tech & others...
    Another thing for interested parties google SSP435 3rd Generation Audi MMI System ... please view page 20 ...
  6. Re: struggling with AMI part numbers
    #46
    Sep 2011
    This is part no for the retro fit kit at Audi ... so they have officially recognised the retro-fit ...
    I have PM'd you the original thread concerning the retrofit, you will see it is dated April 2011 ...
    P/N for lead is 4F1 971 086 B approx. £175 @ dealer ...
    P/N for port trim in the glove box is 4F0 035 909 approx. £4 @ dealer ...
    are you sure about the part numbers?
    Please follow instructions in PM and view info ... what you do is your choice ...
    You have Kaufatec option = approx. £330
    You have ebay dealer option = approx. £250
    You have dealer route option = approx. £180
    I feel we have given you enough info and you have found another guide which confirm A8 Tech's retro instructions...
    So I'm now ...
    ATB
    G
    1 1 0
  7. Re: struggling with AMI part numbers
    #47
    Dec 2008
    manchester, UK
    So I'm now ...
    ATB
    G
    G, you have been a great help, thanks very much.
    1 1 0
  8. Re: struggling with AMI part numbers
    #48
    Jan 2011
    Stafford, UK
    Oops - reading too quick!
    On that note, AMI is wired directly into the 5F unit. Jon said it's easy but I'm pretty sure you need some sort of activation dongle/update from Audi to enable the feature.
    You can keep your changer as AMI is located on the roof of the glovebox and only the port is showing, unlike the 2G where its a seperate box.
    Anything here any good ? - AMI (Audi Music Interface) part numbers / Notes on retrofitting AMI (A4/A5/A6) (by LoCal) - Audi A6 Q7 A8 A4 A5 Retrofit Jälkiasennus Nachrüsten Retro-fit
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  9. Re: struggling with AMI part numbers
    #49
    Dec 2008
    manchester, UK
    Where I am up to following conversations with various Audi dealers and TPS:
    4F0051960 is a full kit including SVM codes. Dealer supply, fit and code £480, supply only £335, coding only £86.81. TPS price supply only £179.17 (+VAT?).
    4F0035909 and 4F1971086B are the components of the above kit. no codes or instructions come with these.
    What I'm doing now/next: waiting to hear back from my indy about coding;
    From what I understand I can vag-com/VCDS it, knowing that the dealer will delete at service. When the car goes for service I will give Audi the codes etc for permanent coding. i'm confident that I can fit the cable myself, in fact it looks far easier than the reverse camera install I did on my previous Passat B6 (angle grinders were necessary!).
    1 1 0
  10. Re: struggling with AMI part numbers
    #50
    Sep 2008
    mostly in the garage
    I think what happens at the dealer is when the car is hooked up to the Vag system any code differences are flagged for the tech to check against installed equipment where possible before allowing/deleting changes.
    1 1 0
  1. Part Numbers
    By KSD in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2013, 11:49 AM
  2. Who knows their part numbers??
    By type49 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2010, 11:38 PM
  3. part numbers??
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 07-09-2009, 01:47 PM
  4. VW Part Numbers
    By vwmark in forum Chat - Anything with wheels
    Last Post: 19-03-2007, 03:09 PM
