Thank you
... mine is not the most option loaded but more than some others ... one of the reasons I have kept ploughing the £££ in it is if I looked at getting another and then perhaps retro fit some elements I'd blow mega £££ ... for instance on the MMI 2G AMI & DAB are
not complicated or costly retro fits
but MMI 2G Basic/Basic + to High is costly/complicated ... converting from halogen to xenon's again is £££ ...
I would possibly make a list of must have options & ones you'd like, some options are rarer to find on the used market, I've been peaking at the Autotrader virtually all days since having issues, just to justify what I've been blowing on my car
What you are looking at is
very worst case scenarios plus mine was on long life servicing from new til 70k miles which IMO exaggerated issues. Due to your current prospective purchase being a 2008 it has the superseded injectors,
mine did not. Yours will have the improved chain tensioner,
mine did not. Again the multitronic gearbox is improved vs a 2004 to 2007, IIRC 2007 was when they improved design will try to double check as I need to put that in the "V6 buyers" thread.
There are plenty of early V6 owners which have not had issues,
same goes with the 2.0 TDi ... the later car you buy will have improved software in modules and parts ... if your budget stretch to a facelift car ie 2009 -11
I would go for that instead if buying again ...
MMI 3G Low is standard in facelift cars which is kinda same/better than MMI 2G high
but retros to it are done differently vs 2G...
MMI 3G High has HDD nav/jukebox which is sweet IMO
... on the facelift Xenon equipped cars you have those cool LED DRL's ...
The 2.0 TDi on the facelift is common rail and you can get a 170 BHP version which is close to 2.7 on power but with more economy
PM c4a5er once you got more than 10 posts he had a Touareg V6 and went to a facelift A6 2.0 PS170 and enjoys it
No worries mate
, I'm just an owner I've had a hard time with mine and some of the suggestions are things I'd do if buying again ...
Yes if engine/gearbox oil has been done regular they are sound as a £
and you shouldn't have anything to worry about ...
From what I've seen in the past 20 mths of being glued to forums the MMI/ECU are solid, the amount of failure just due to failing on its own accord is very low that no one should worry about it IMO ...
Yes that's normal ... to the left of the MMI screen is a "Check" button push that when car is started and it will go through the check system, if it flick through all checks all is well, if it displays/pauses on just one or more check screen and a message there is a fault related to that ... I will do a video and upload later today
Mine has a little on the lowest edge, some elements of trim have a soft feel coating on them which does wear off with use ... on the facelift car some of those elements have been improved with a different coating ... in the case of the EPB switch it has a chrome section where most wear on coating would occur ...
Check all things work ... something for you to read Link:-
Setting Clock / date
