Thread: Pressure Washer
Results 1 to 10 of 12
  1. Pressure Washer
    Mar 2007
    Bedfordshire
    I needed to give my decking a clean as its not been done in 3 years.
    I decided to borrow a pressure washer rather than use chemical cleaners.
    I did not know just how effective they are.
    Have a look at the pic on the link
    Because of the size of the spray at a height that worked. (1.5 inches) this took me two days. (about 5 hours)
    The size of the decking is 7.2m by 2.4m
    http://www.vwaudiforum.co.uk/photopo...ze=big&cat=500
    Current Car: Skoda Octavia vRS Hatch 2.0TDi 170 CR in Candy White
    Outgoing Car: 2007 56 Plate Audi A3 Sport Sportback 2.0TDi 170 PD in Black
  2. Re: Pressure Washer
    Coventry
    They are also good on slabs which can get slippy
    Imagine what it would do to your skin.
  3. Re: Pressure Washer
    Mar 2007
    Bedfordshire
    There was that as well, we had ivy growing up our brick coal shed. so when i took it all down the other year, it left the bricks on the shed looking quite green.
    Not anymore
    I keep looking around finding other things to wash.
    The garage wall will be next.
  4. Re: Pressure Washer
    Dec 2006
    Rather than borrowing.... i got a decent one from B&Q for £30 which has ample pressure to do the job..
    RickT
  5. Re: Pressure Washer
    Mar 2007
    Bedfordshire
    it was a proper borrow, not a borrowed but not paid.
    It will go back and I shall be investing in one.
    The thing that concerned me was the amount of water it was using.
    Can you use a water butt with rain water in it?
  6. Re: Pressure Washer
    Aug 2007
    Northern Ireland
    Yes you can, make sure the washer has a filter on the inlet pipe though! Also, the more volume (litres per minute) along with pressure (psi) the more you will wash off in one go.
    Get something decent like 8L/min@1750psi or better
    Pete
  7. Re: Pressure Washer
    Mar 2007
    Bedfordshire
    Thanks. I feel a bit better about getting one now. Running it off the mains seemed wasteful.
  8. Re: Pressure Washer
    Aug 2007
    My Mum bought one a few years back and started to cleaned our back yard with it. After about 20 minutes she complained it was taking ages and didn't seem to make much difference.
    Turned out the fuse had gone in the extension lead and it had never actually been turned on :-)
  9. Re: Pressure Washer
    Coventry
    dunno if i'd run one off a water butt as i thought they had to have a pressure in the supply as the pump in it is not meant to suck water, it is for pushing water out.
  10. Re: Pressure Washer
    Gwent
    I borrow my dad's sometimes, I can't recommend the floor cleaning attachment enough. It's like a sprinkler head inside a box. It leaves swirls like a milling cutter if you go too fast, but does an 8" wide stripe perfectly, if you go slower. The bonus is it's like hoovering so even the missus can do it...
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Rear washer jet?
    By AWH in forum Chat - Completely Off Topic
    Last Post: 01-11-2008, 02:40 PM
  2. 02 A6 Washer Leak
    By akh747 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-07-2007, 04:00 AM
  3. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
  4. Rear washer
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 25-05-2007, 04:41 PM
  5. A4 leaking washer
    By fredhew in forum Chat - Completely Off Topic
    Last Post: 01-03-2007, 12:48 AM
