Thread: Rear wheel bearings, complicated?
Results 1 to 10 of 11
  1. Rear wheel bearings, complicated?
    Mar 2009
    York
    Further to my previous post about excess road noise, I am now convinced I have a bearing at the rear starting to fail,
    I have a noticeable drone from 15mph upwards, very noticeable. I swapped front to rear tyres to eliminate sawtooth and there was absolutely no difference.
    The warranty garage is non-VW. Do you need vcds to check and/or replace rear bearings?
    Thanks for any help, I'm ringing the garage tomorrow - bearings are clearly stated as a covered item.
    Paul
    Edit: noise definitely from the rear - lean forwards towards the windscreen you can hardly hear it, lean back in your seat and Bang! It's there!!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: Rear wheel bearings, complicated?
    UK Ex-pat now in Australia
    You may need to use diag equipment to loosen the rear pads off to remove all other parts etc and then to basic set the brakes after the bearing is replaced.
    Although the wheels were swapped are different tyres fitted as it can be the tyres that are noisy due to the material of the tyres.
    Had MKV GTI, Now Ford Falcon
  3. Re: Rear wheel bearings, complicated?
    SE London
    Have your 4-wheel tracking done first by a Laser equipped place. I used a Hunter franchise when my drone started
    But she's fine now. So is the road noise.
  4. Re: Rear wheel bearings, complicated?
    Pembrokeshire
    22 Post(s)
    jack it up and spin the wheel furiously as fast as you can . use something like a small piece of wood through the wheel. you can usually hear a grumble if the bearing is shot.
  5. Re: Rear wheel bearings, complicated?
    Mar 2009
    York
    Ok, so there are loads of variables at the moment, so it is booked in under warranty and I'll see what they say. It is pretty much black and white though... It's either the bearings or it isn't.
    If it isn't then ill start looking at the tyres and go from there. Cheers
  6. Re: Rear wheel bearings, complicated?
    Mar 2009
    York
    Zollaf, I tried spinning it but not very quickly when it was jacked up on the drive. Didn't quite know what to listen for but all I could hear was the pads against the disc - it would do half a rotation then stop with the friction. The fronts spin relatively freely. Connected or not???
    Thanks!!
  7. Re: Rear wheel bearings, complicated?
    Pembrokeshire
    22 Post(s)
    should really spin a bit better than that.
  8. Re: Rear wheel bearings, complicated?
    Mar 2009
    York
    I may be remembering wrongly, maybe it spun a bit better but there definitely was the noise of pad against disc. The fronts don't quite have the same sound - they spin almost silently.
    However these brakes were only fitted two months ago and unless pads can shift by themselves I'd think this is not connected with the droning sound.
  9. Re: Rear wheel bearings, complicated?
    Mar 2009
    York
    Mini eureka moment here... Maybe what I am hearing from the rear wheels isn't the brake discs at all, it could be the rough sound of the bearings themselves. Would explain why the fronts are much quieter as all brakes were new at the same time...
  10. Re: Rear wheel bearings, complicated?
    DSG4ME Guest
    Curve ball time,
    Get someone to sit in the back on the kerb side and drive, that drone could be the lift pump on it's way out, mine gave me ear ache such was the drone it made.
  1. rear wheel bearings
    By Redzer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-11-2011, 08:56 PM
  2. A3 rear wheel bearings
    By egTT in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-04-2010, 10:46 PM
  3. B7 rear wheel bearings
    By dabsline in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-06-2009, 07:38 PM
  4. Rear Wheel Bearings
    By darobsta in forum Eos
    Last Post: 18-08-2008, 10:01 AM
  5. Rear Wheel Bearings
    By roobarbii in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2007, 05:56 PM
