Thread: Help?
  1. Help?
    Apr 2013
    York
    Slap in my VAG and this. Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
    Control Module Part Number: 5M0 907 357 HW: 5M0 907 357
    Component and/or Version: AFS-Steuergeraet X016
    Software Coding: 0000006
    Work Shop Code: WSC 00028 028 00001
    Additional Info: ID-L fehlt AFS-Lst.-Modul l .... ID-R fehlt AFS-Lst.-Modul r ....
    VCID: F1E34B1DE8B2BB1
    6 Faults Found:
    01042 - Control Module; Not Coded
    000 - - - MIL ON
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
    000 - - - MIL ON
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
    000 - - - MIL ON
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    02233 - Left Headlight Power Output Stage (J667)
    004 - No Signal/Communication - MIL ON
    02234 - Right Headlight Power Output Stage (J668)
  2. Re: Help?
    46 Post(s)
    Clear and rescan and see what returns.
  3. Re: Help?
    Apr 2013
    York
    Hi, sorry for not going indepth, I did clear and rescan same errors, thing is this car the last owner crashed the front end, the headlights must've been replaced with either fakes or non Xenon headlights, Now, i'm awear that my AFS module is behind my glove compartments so I no I aint missing it. would it be that I need to buy OEM Xenon headlights and correctly wire them up? Avid Mechanic here..
  4. Re: Help?
    DSG4ME Guest
    Check if the bulbs are the correct ones, LED's etc will throw fault codes, to check if it's Xenon or not simply wait until dark and look at them on from a distance, if they purple blue in colour they will be Xenons, if they white they be H7's and if they white but blinding then they are some aftermarket xenon lookalikes which will also throw a code.
  5. Re: Help?
    Norfolk
    Quote Originally Posted by Flntn View Post
    I'm sorry but your posts don't make any sense. Your car either has factory fit xenons or it doesn't. Just look to see what you have. Normal headlights do not look like oem xenons. Look at the bulb fixings etc. The handbook will give you a guide. The sticker in the boot well should also give a code for factory fit xenons/ or not.
