Thread: 2004 Golf GT TDi front supension strut.
  1. 2004 Golf GT TDi front supension strut.
    Apr 2007
    Devizes
    I've been looking after this Golf for someone while they're in NZ, don't want to give it back to be honest.
    Just failed it's MOT for the NSF shock absorber strut excessive fluid leakage. Indeed, all the caked on mud looks wet around it.
    Picking a new one up later for £45+vat and gonna be changing it myself this week. Is there anything I should know about that isn't covered by Haynes?
    Can't find anything in the forums about changing them apart from one person mentioned this has been an old MOT testers' trick in the past and that they are gas filled not oil?!?!
    Cheers for the help.
    Car is a 2004, 1K, 2.0l GT TDI Sport, 103kw, BKD engine.
    Ta, Sly.
    AUDI A3 1.8T 2001 X AUM AUTO LHD DENTS DIRTY-CARPETS!
  2. Re: 2004 Golf GT TDi front supension strut.
    Jun 2007
    Up North
    Many year ago, when cars were so unreliable every man carried a box of tools or a towrope in the boot, it always used to be a favourite at *cough* major tyre suppliers, who also do exhausts, brakes and shockers. You had to look out for a old fashioned oil can squirter in the bottom of the pit or by the ramp. They just happened to spot your "leaking" strut when fitting new tyres or doing the pads. Maybe the growth into MOT testing has brought an old friend back to life?
    I've seen it done (but not at the one with the blue logo, it was a smaller outfit, who were nevertheless nationwide and have now been absorbed by one of the chains). The guy who's car it was wasn't as dumb as they expected, spotted the con straight away and I thought he was going to punch someone! The halfwit who did it had even left the can there for him to spot. It only ever seemed to happen on cars that were easy to swap shockers on .................
    That's why I always get my MOT at a dedicated centre that does no repairs.
    Chances are, all is kosher, but if in doubt clean it all off, degrease with meths or something similar and take it for a thrash before re-inspecting.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  3. Re: 2004 Golf GT TDi front supension strut.
    Apr 2007
    Devizes
    Cheers Teflon, I think I trust this garage as they know I do repairs myself so have nothing to gain.
    Never easy though is it?! One of the bottom ball joint bolts sheared and I can't get the drop link top nut off, joint just spinning and allen key hole rounded out. Looks like it's gonna be an angle grinder job. VW also seem to have put on nuts that need double depth 16 and 18mm sockets, standard in anyone's tool kit, NOT!
  4. Re: 2004 Golf GT TDi front supension strut.
    Pembrokeshire
    22 Post(s)
    a gas shock is still full of oil, it just has some pressurised gas above it to help prevent foaming, so they still leak just the same as normal oil shocks do.
    i would do both sides though, or the front of the car will be unbalanced, increasing your chances of crashing.
    2 0 0
  5. Re: 2004 Golf GT TDi front supension strut.
    Apr 2007
    Devizes
    Quote Originally Posted by zollaf View Post
    That explains it then! I just read the responsible disposal notes with the new strut and had sort of worked it out.
    I love how matter-of-factly you say that! This side first to win the MOT then I go away for a month and will do the other side when I get back. Just bought the extra tools needed for this so at least they'll get some more use then...
  6. Re: 2004 Golf GT TDi front supension strut.
    Pembrokeshire
    22 Post(s)
    [QUOTE=Sly;807059]
    i don't beat around the bush. brake really hard, one front wheel is planted because the shock is new and works. the other side bounces a little, due to an old worn shock. this inbalance sends the car into a spin. it happens.
  1. Front springs/strut
    By stu.gtx in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-09-2010, 10:16 PM
  2. Please Help Front strut/hub needed!
    By evzybaby in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2009, 08:01 PM
  3. front strut? golf gt tdi???
    By betrayed in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 02:23 AM
  4. front strut clearance on vr6
    By lmg356 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-02-2008, 09:00 PM
  5. Mk4 Golf Front Strut Top Mounts
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-06-2007, 11:09 AM
