Thread: Cheapest way to connect an AUX or iPhone connection
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
  1. Re: Cheapest way to connect an AUX or iPhone connection
    46 Post(s)
    None of those will work as the RNSE uses the multimedia plug on the rear
    What you need is -
    AUX IN Nachrüst Set Audi RNS E Klinke mp3 Player Nootebook iPhone MiniDisk 37898 | eBay
    And yes the RNSE is quadlock.
  2. Re: Cheapest way to connect an AUX or iPhone connection
    Mar 2012
    London, England
    Hmm, from the description on those listing it seems they should work right? I don't really mind even if I have to take out the cd changer and connect it. Obviously the ones you specified, seems to allow the cd changer to stay in place.
    When searching places like ebay, assuming I have enabled the AUX via VCDS, what do I need to be looking for, i.e. what connector type, feature etc so I know it'll work. As the links that I gave first led me to believe they would work?
    What about this, it seems to be cheaper and should work right? allanmb has used this.
    http://www.ebay.co.uk/itm/AUDI-AUX-I.../130833048720?
    The listing describes:
    Compatible with quadlock connection head units which has a 32pin grey connector slot
    Fits all Audi models with RNS-E sat nav unit
    NOT compatible with MMI systems
    Aux MUST be available to select before purchasing this lead
    This one seems to be a fair bit cheaper too...
  3. Re: Cheapest way to connect an AUX or iPhone connection
    46 Post(s)
    The AUX will only work if its wired in through the multimedia plug shown on my link above, it will not work if wired through the quadlock.
    That link would've worked (its ended) but it wont give you the fancy little port to place on the dash, just a cable in the glovbox or wherever you want to place it for the device.
    As long as any listing shows the multimedia grey plug it will work.
  4. Re: Cheapest way to connect an AUX or iPhone connection
    Mar 2012
    London, England
    Cheers Chris, so you agree this would work or something like this, right?
    AUDI AUX IN IPOD MP3 A1 A2 A3 A4 A6 TT Q3 Q5 Q7 RNS-E RNS E 2M CABLE | eBay
  5. Re: Cheapest way to connect an AUX or iPhone connection
    46 Post(s)
    Yep that will work but obviously just not as neat as the AUX port
  6. Re: Cheapest way to connect an AUX or iPhone connection
    Mar 2012
    London, England
    Aha, I was wondering what that black box is, I can't see any holes? I wouldn't even know where or how to secure that box with the car lol. I think i'd be better off with a hanging 3.5 connector rather than that box lol
  7. Re: Cheapest way to connect an AUX or iPhone connection
    #17
    Mar 2012
    London, England
    Hey buddy,
    I've sent a guy a message asking to use his VCDS, just waiting on a response, was just wondering, is it an obvious option to enable the AUX feature? Like an on/off in audio settings or something? Or is it more complicated like changing codes etc?
    I've found this post for an adapter which i'm hoping to buy, seems a good price:
    RNS-E AUDI NAVIGATION PLUS A3 A4 A6 AUDIO AUX IN ADAPTER ADAPTOR AUX-IN IPHONE | eBay
  8. Re: Cheapest way to connect an AUX or iPhone connection
    #18
    46 Post(s)
    You definitely need vcds.
    Select 56 Radio or 37 Navigation, then press Coding 07 and change the 6th digit to a 5. (0xxxx5x). Once you have commited this change you will need to do a reset of your RNS-e by pressing Radio+Setup simultaneously until the unit restarts. Once the unit is powered back up select CD and under the sources menu you should now have AUX.
    1 1 0
  9. Re: Cheapest way to connect an AUX or iPhone connection
    #19
    Southern County Softy
    20 Post(s)
    sorry to jump in.. .just coded my nav and now have AUX option. If I fit the cable as shown on the german ebay link what can I plug in ? just to recap I don't have a multi changer in the glovebox and was thinking of routing the cable to the armrest.would I need any other cables ??
    A4 2.5 tdi QS (mapped)
  10. Re: Cheapest way to connect an AUX or iPhone connection
    #20
    46 Post(s)
    Should be 100% George although not sure how it work with the changer already there, could you check the back of your RNSE and see if its plugged into the multimedia plug thing?
  1. Question Can my car connect to iPhone?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-01-2013, 09:12 PM
  2. How to connect an iPhone for streaming music
    By xtremist in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-01-2012, 11:08 PM
  3. Please Help cant connect to aux water heater using vag com on my sharan.
    By nopacman in forum Touran - Sharan - Caravelle
    Last Post: 23-12-2011, 04:28 PM
  4. Cheapest way to get AV connection
    By yesheadjon in forum In Car Entertainment
    Last Post: 29-05-2008, 11:25 AM
