Thread: Squeaking noise on lock/when cold
  1. Question Squeaking noise on lock/when cold
    Aug 2008
    Wigan
    9 Post(s)
    Hi everybody. Looking for some advice about my 2002 1.9 Tdi SE, PD100 engine (ATD I think) with aircon. It's concerning a squeaking noise which occurs on full lock and also just after a cold start. I thought it would be the alternator/power steering belt so I changed that and it seemed to go away but it's back.
    Does this engine have alternator pulley problems or is it going to be a slack tensioner which needs replacing? The tesnioner is wobbling up and down when it's idling, as though the spring may be tired and not pushing as hard as it should. It's done 99,000 miles.
    Any advice appreciated.
  2. Re: Squeaking noise on lock/when cold
    UK Ex-pat now in Australia
    It is most likely the free-wheeling pulley on the alernator - they are very common.
    Had MKV GTI, Now Ford Falcon
  3. Re: Squeaking noise on lock/when cold
    Pembrokeshire
    22 Post(s)
    easy enough to check. just use a small pointy thing to see if you can turn the alternator fan through the casing. it should be able to turn in the direction the engine would spin it, but not the other. if you can't turn it, you need a new one, which i can pretty well say for sure you do.
  4. Re: Squeaking noise on lock/when cold
    Aug 2008
    Wigan
    9 Post(s)
    Two Questions on this one:- (i) Do all PD100 engined Mk IVs have the freewheel alternator pulley? (ii) If it's the pulley, why do I get the squeak when I put load on the power steering i.e. full lock (it stops when the steering is let go)?
  5. Re: Squeaking noise on lock/when cold
    Dec 2011
    Swindon
    9 Post(s)
    Yes i think they all have the free wheel bearing. When you put load on the steering, the power steering pumps works hards which is connected to the Aux drive belt. My MK4 had this problem and changing the free wheel bearing on alt solved it right away. I did read one post in here or another MK4 site, that the power steering fluid level might be too low or might need changing, so might be worth checking that before the £35 of a new bearing.
  6. Re: Squeaking noise on lock/when cold
    Aug 2008
    Wigan
    9 Post(s)
    Thanks for the replies; I had another think about it and realised the load on the power steering would put tension in the belt and cause the squeak. Checked under the bonnet and yes it has a freewheel pulley and yes it's jammed. Sourcing a part today, the tool to change it is on it's way so it looks like a little job coming up for the bank holiday weekend.
  1. Squeaking Noise
    By SattyA4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-03-2013, 01:35 PM
  2. Important Cluch squeaking noise
    By nunoaraujo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2012, 08:25 PM
  3. squeaking noise
    By saif786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2009, 08:23 AM
  4. Squeaking Noise??
    By take_this_oath in forum Audi A3 - Archive Topics
    Last Post: 21-02-2008, 09:52 AM
  5. Squeaking noise when driving
    By langhurst in forum Eos
    Last Post: 26-02-2007, 06:01 PM
