Thread: golf 2 engine swop 8v to 16v possibilities?
  1. golf 2 engine swop 8v to 16v possibilities?
    Aug 2007
    nailsea near bristol uk
    hello there
    was wondering what option i would have on a power plant swop on my golf 2, it currently runs a 1600 8v, would like a 1800 16v gti motor or similar wondering what option there are and how much stuff on the car would need changing.
    thanks in advance
    john
    Gold 1988 golf mk2 1600 8v
  2. Re: golf 2 engine swop 8v to 16v possibilities?
    Mar 2007
    coventry
    is the mk 2 golf injection ?
    no matter how you try you always come back to what you first started
  3. Re: golf 2 engine swop 8v to 16v possibilities?
    Jun 2007
    nuneaton
    yes to help you we need to know if the engine that is fitted is injection ?
    if so this is much easier to build on than a carb model
    hope this helps
  4. Re: golf 2 engine swop 8v to 16v possibilities?
    Feb 2007
    Surrey Hants border
    if it is a mk2 1600 then it's a carb engine
    to swap to 16v gti you will need
    full fuel system
    the engine wiring looms plus all other components i.e computer amplifier etc etc
    full exhaust system
    16v engine and clutch plus gearbox (16v splines are different size ) could always use an early mk3 gti box better gearing and poss less miles same splines as 16v.
    cooling system the radiator is bigger fan should be 3 pin 2 speed yours may only be 2 pin 1 speed
    So basically you need a donor car and its a lot of work!
    plus brakes and suspension if you want even a reasonable qoute from your insurers and be safe on the road too
    you are limited to @165bhp unless you want to start spending a lot of dosh and then you might as well buy a crashed audi /passat and drop a 1.8 T in
  5. Re: golf 2 engine swop 8v to 16v possibilities?
    Aug 2007
    hey people thanks for the replies so far
    yes it is a carb engine it is a pierburg solex 2e2 carb on the 1600ez motor
    so what you guys are saying is get a donor car, couple of mates, a long wknd and a crate or three of beer to do it.
    bit of a nightmare in other words.
    cheers
    john
  6. Re: golf 2 engine swop 8v to 16v possibilities?
    Feb 2007
    Surrey Hants border
    ring me re the conversion
    i am breaking an 8v today and if you want the rear axle roll bars etc etc very cheap
    drive shafts most of what you would need for the change
    plus have loads fo powerflex polyurethane suspension bushes for sale
    07884056345
    Martin
  1. VW Golf Engine Cut Out
    By burnsie20 in forum Archive posts
    Last Post: 04-09-2007, 06:18 PM
  2. Golf GTi-T - Engine problem
    By elemental in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-06-2007, 05:18 PM
  3. AHF Golf engine
    By dreamworx in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 10:15 AM
  4. Engine Oil for Mk 4 Golf
    By Reet in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-12-2006, 02:28 PM
  5. Golf GT TDI 110 - Engine Wobble?
    By gt_tdi_si in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-10-2006, 05:37 PM
