Thread: Rear Brake light warning light
  1. Rear Brake light warning light
    Apr 2013
    London
    Hi all
    Had a 09 Touran for 9 months. Get the feeling I might be having for much longer but would love to see what the thoughts are on here.
    The light came on to signify my rear brake light was not working. I managed to take out the light unit and all bulbs were fine. Stuck it back in and light cleared.
    Came back today and its back on. Checked all bulbs again and all ok. Disconnected wiring loom and then put back and restarted ignition.
    One again light went but I have the feeling this may be a issue with the power supply unit.
    If so how much is that part? and does anyone know if it would be covered under them extended warranties.
    Many thanks for any feedback
    James
  2. Re: Rear Brake light warning light
    46 Post(s)
    Is there any corrosion on the bulb holder contacts?
  3. Re: Rear Brake light warning light
    Apr 2013
    London
    Thanks for the reply. Looks pretty clean to me but guess I could check with a multimeter if it happens again. Would be nice to see if anyone else has had similar issues
  4. Re: Rear Brake light warning light
    Southern County Softy
    20 Post(s)
    Bulb warning systems are quite sensitive, they work on resistance so sometimes flag up a bulb before it blows.
    I wish I could tpye...
    A4 2.5 tdi QS (mapped)
  5. Re: Rear Brake light warning light
    Apr 2013
    London
    Quote Originally Posted by kite View Post
    Just to let you know it was the bulb. Must have been exactly what you mentioned.
    James
  1. 2007 A6 3.0 Allroad - Is there brake pad wear warning light on rear?
    By Roygarth in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-12-2011, 07:35 PM
  2. ABS warning light & flashing brake light
    By mrbiondi in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2011, 01:47 PM
  3. Question Avant, Rear brake light warning on dash, bulb is OK though!
    By ally0000 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-07-2010, 02:49 PM
  4. Rear Brake light out warning
    By noshock65 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2008, 10:48 AM
  5. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
