Thread: 01 Audi A3 VAG-COM Codes
  1. 01 Audi A3 VAG-COM Codes
    Mar 2013
    Shotts
    Hi guys, can you help me please diagnose the below...and what I need to do to fix things?
    01 - engine
    VCDS-Lite Version: Release 1.2
    Wednesday, 17 April 2013, 18:17:39.
    Control Module Part Number: 06A 906 033 J
    Component and/or Version: SIMOS33 1,6l 2V 00HS3488
    Software Coding: 00211
    Work Shop Code: WSC 06435
    VCID: 263F759BD1FF
    Additional Info: WAUZZZ8LZ1A015212 AUZ5Z0Y5303082
    4 Faults Found:
    17810 - EGR Valve (N18): Short to Plus
    P1402 - 35-00 - -
    17811 - Shareware Version. To Decode all DTCs
    P1403 - 35-10 - Please Register/Activate - Intermittent
    17700 - Shareware Version. To Decode all DTCs
    P1292 - 35-10 - Please Register/Activate - Intermittent
    16726 - Camshaft Position Sensor (G40): Signal too Low
    P0342 - 35-10 - - - Intermittent
    03
    Wednesday, 17 April 2013, 18:26:12.
    Control Module Part Number: 1C0 907 379 E
    Component and/or Version: ESP FRONT MK60 0103
    Software Coding: 0011266
    VCID: 2C2B87B3CF13
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    35
    Wednesday, 17 April 2013, 18:34:33.
    Control Module Part Number: 8LO 862 257 A
    Component and/or Version: ZV-Pumpe, DWA D03
    Software Coding: 01288
    Work Shop Code: WSC 06313
    VCID: 52D7F94B8DF7
    17 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01372 - Shareware Version. To Decode all DTCs
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Shareware Version. To Decode all DTCs
    01369 - Shareware Version. To Decode all DTCs
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01373 - Shareware Version. To Decode all DTCs
    01366 - Shareware Version. To Decode all DTCs
    01361 - Switch for Anti-Theft Alarm; Close
    29-00 - Short to Ground
    01360 - Shareware Version. To Decode all DTCs
    29-00 - Please Register/Activate
    01362 - Shareware Version. To Decode all DTCs
    01363 - Switch for Central Locking; Driver's Door (F59)
    27-00 - Implausible Signal
    01364 - Shareware Version. To Decode all DTCs
    27-00 - Please Register/Activate
    01365 - Shareware Version. To Decode all DTCs
    01365 - Lock/Unlock Switch; Interior
    28-00 - Short to Plus
    01389 - Shareware Version. To Decode all DTCs
    45
    Wednesday, 17 April 2013, 18:35:27.
    Control Module Part Number: 4B0 951 173
    Component and/or Version: Innenraumueberw. D03
    Software Coding: 00001
    Work Shop Code: WSC 00000
    VCID: E0B3A383735B
    2 Faults Found:
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
    01383 - Shareware Version. To Decode all DTCs
    Thanks.
  2. Re: 01 Audi A3 VAG-COM Codes
    46 Post(s)
    The engine would be handy to know.
  3. Re: 01 Audi A3 VAG-COM Codes
    Mar 2013
    Shotts
    Sorry mate...new to all this.
    1.6L Petrol.
  1. Audi A6 2.5TDI 2002 - VAG CODES points to faulty TCM
    By dutyhero in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-12-2011, 07:43 PM
  2. Help with Vag-Com Codes
    By a4katy in forum VCDS - Help Requests
    Last Post: 19-10-2011, 06:16 AM
  3. Vag Com Error Codes from my 2007 Audi 2.0TDI SE Saloon - BRE Engine
    By James1965 in forum VCDS - Help Requests
    Last Post: 02-03-2011, 11:47 PM
  4. Vag Com codes
    By pg20 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-11-2009, 02:29 PM
  5. Audi A6 1.8T VAG Codes
    By iainbrads in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2007, 01:34 PM
