Thread: testing glow plugs
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
  1. Re: testing glow plugs
    #31
    vcds states 76.5 degrees , dash states 90 ...... is this a thermostat issue lads ??????? I also logged a file , cant get it to turn into excel graph ....
  2. Re: testing glow plugs
    #32
    Gwent
    I've had thermostat issues with both of mine, highest VCDS temp was about 74-75 deg C with the gauge showing slightly less than 90 (less than a needle width). It does make them thirsty, but would not give a starting issue. I was more concerned about what the cold coolant temp, should be ambient or thereabouts?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: testing glow plugs
    #33
    Quote Originally Posted by scotty33 View Post
    Fuel Temp Fuel cooling state Intake Air Temp Coolant Temp
    ~Amb.Temp.*C On:100%-Off:0% ~Amb.Temp.*C ~Amb.Temp.*C
    °C % °C °C
    10.8 0 12.6 13.5
  4. Re: testing glow plugs
    #34
    Norfolk
    Can you post the measuring block (007 I think) that has the coolant, fuel and air temps. You need to get a reading when the engine is cold and another when it is fully warmed.
  5. Re: testing glow plugs
    #35
    Quote Originally Posted by martin1810 View Post
    those figures above martin , are the start of my journey , here's the last few rows of a 20 minutes trip ..
    55.8 0 25.2 76.5
    55.8 0 25.2 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 24.3 76.5
    55.8 0 25.2 76.5
    55.8 0 25.2 76.5
    55.8 0 25.2 76.5
    55.8 0 25.2 76.5
    55.8 0 25.2 75.6
    55.8 0 25.2 75.6
    55.8 0 25.2 75.6
    55.8 0 25.2 75.6
    55.8 0 25.2 75.6
    55.8 0 26.1 75.6
    55.8 0 26.1 75.6
    56.7 0 25.2 75.6
    56.7 0 25.2 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
    56.7 0 26.1 75.6
  6. Re: testing glow plugs
    #36
    Norfolk
    The temps are difficult to evaluate because I don't know what the figures were like where you live. The last few days in Norfolk we have had near 0 C temps over night so coolant temp wouldn't be 13.5 C at start up. Perhaps it's warmer where you live. The end journey coolant temps are wrong. They are too low. At 75 C you will probably be running on the wrong injection map and using extra fuel. I still think you should check and clean the coolant sensor connectors and the ecu connector but you probably need a new thermostat. Thermostat won't help the starting though.
  7. Re: testing glow plugs
    #37
    I know the stat wont help starting , but its something I noticed that's all to be not right ... today things took a turn for the worst , the car now simply refuses to start as if no fuel at all is getting in , and when it finally does fire even when hot , the idle is all over the place , the boost is a bit slow also coming on as if its waiting for fuel also .... no fault codes ,I was going to change the fuel filter,, and it will only fire up when I remove the ect sensor ---- Im giving up on the diy approach and im taking it to a mechanic next week , I cant see him wanting to change the timing belt etc when its running like a bag of shyte ..... fed up now !!!!!!!!!!!!,
  8. Re: testing glow plugs
    #38
    Gwent
    Can a sticky dual mass flywheel affect starting?
    Passat 130 tdi, have you read fault codes, now it is not starting?
  9. Re: testing glow plugs
    #39
    I hope this is my problem .... and no I wont be going anywhere until its changed ... video 3 is today , the other 2 were 2 weeks ago when my problem began.... http://smg.photobucket.com/user/male...ddcc8.mp4.html http://smg.photobucket.com/user/male...d5577.mp4.html http://smg.photobucket.com/user/male...2302f.mp4.html I could hear it slapping against the covers today , so just thought i'd have a look inside..... im thinking the pump timing on start up is out and once running the ecu is correcting the timing .. ??? or am I wrong ?????
  10. Re: testing glow plugs
    #40
    Feb 2010
    luton uk
    you may find that changing the belt and a new tensioner may cure your problems if the belt is as loose as it is in the videos , it may have jumped a cog or two did it start giving you trouble after giving it some hard acceleration from a junction by any chance ??????
    "A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
    Winston Churchill
  1. glow plugs
    By jambojr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-05-2012, 01:38 PM
  2. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
  3. Question Glow Plugs
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2011, 12:04 AM
  4. Glow plugs
    By hagis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-10-2008, 02:56 PM
  5. Glow plugs
    By ky_bren in forum Golf MK3 - 1993 - 1999
    Last Post: 06-05-2008, 07:51 AM
