Thread: VW FOX 07 Window regulator
  1. VW FOX 07 Window regulator
    Apr 2013
    England
    Wondering if someone would be able to help. The window on the front passenger side has fell down. I've took off the door panel but then I can't work out how to get to the window regulator. Can anyone help?
  2. Re: VW FOX 07 Window regulator
    Nov 2012
    manchester
    hi i dont know if this will help you its the procedure to remove the window but may help
    Remove the front door lining → Body - Internal assembly works;
    Remove sealing membrane.
    Lower door window glass until the support is accessible on the window activation mechanism.
    Remove -arrow A- clips -2- and -3- and press door window glass -1- in -direction B-.
    If window cannot be lowered with window power activation mechanism because of damage, remove clamp -2- through another door opening (if necessary, use a screwdriver or similar) and press door glass window -1- first on clamp -2-.
    Then, pull door window glass in -direction C- and press support on clamp -3- (elongated).
    Lift the door window glass from behind, turn outside the door forward and, towards -arrow-, forwards.
    Install
    Installation is performed in the reverse sequence; in this case, observe the following:
    After assembling the door window glass, you must check the operation of the window drive mechanism.
  3. Re: VW FOX 07 Window regulator
    Jul 2014
    bristol
    Hi, Ive just had the same thing happen. did this help above help you fix it, if not how did you get to the mechanism?
  4. Re: VW FOX 07 Window regulator
    Jul 2015
    Wales
    Hi I've managed to source a part but it's saying it's not a Comfort mode I'm not really bothered about that my only concern is will the plug fit in to The which had the comfort mode function. Does it matter about this and will it plug in. Many thanks bob
  1. Window Regulator
    By zoomered in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2011, 07:51 PM
  2. Please Help Window Regulator
    By kite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-11-2010, 02:53 PM
  3. n/s/f window regulator
    By estate130 in forum Bora - 1998 - 2005
    Last Post: 07-07-2010, 12:59 PM
  4. window regulator
    By ricechrispea in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2008, 08:06 PM
  5. b5 window regulator
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 28-02-2007, 10:09 AM
