Thread: White smoke after 5 mins of driving, no obvious reasons
Results 1 to 10 of 16
  1. White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    Heckmondwike, England
    So i have an Audi A3 1.9TDI 2008, 94k miles.
    About a week ago i walked upto the car and there was about a cup full of liquid on the floor under the car > looking at the car from the bottom is was near the front left. I reversed off it so i could smell what it was and it was odourless. Seems like water. It was a dry day about 14 degrees. So definitely came from my car. Anyway, i drove home (10 minutes) and left it overnight. In the morning i set off and it warned me about coolant low. So popped bonnet and yes there was about a cup full of water gone from the coolant tank. I topped it back up between the min and max mark and off i went.
    Since that time, after about 5 mins of driving white smoke comes out of the exhaust. Once it comes out it continues out at idle. There is no more/less if i rev the engine. It does have a kinda burnt smell about it but i've never smelt the exhaust before so i have nothing to compare it with. In the last week i've probably driven around 120 miles, 15-20 miles per day with it and it does the same every day, first 5 mins is fine, then it smokes. The engine isn't overheating, i have checked the coolant tank every day and its Exactly where i topped it upto, its not leaking anything. I have checked the oil and its bang on the minimum mark (which is probably where its always been, i got the car about 3 months ago) so there is oil in and i dont think its leaking. There is no scum in the coolant tank, there is no scum in the oil cap.
    It would suggest maybe 1 of the injectors is faulty, but there is no loss of power, or if there is its not at all noticable. I drive around 5 miles of normal road and 10 mile of motorway every day.
    I'm not sure what it is ? a head gasket failure i'd expect to be losing water from my cooling tank ?
    I can't take it to the garage and be without it at the moment because my girlfriend was due to "pop out" our first child on Monday 15th April (yes she's now overdue) so i cant afford to be without my car at work incase she goes into labour.
    Any help ? the engine warning lights etc dont complain about anything. So am i ok thinking that whatever it is, im not breaking it more by driving ? i realise there is of course something wrong but if i can still drive now and book it in the garage after the baby is born, without the cost going from £100 to £1000 because i was driving... that would be a real relief
    Anything else i can check/look at myself ? im not in any way mechanically minded and had to refer to the manual just to try figure out if i even had a radiator valve to look in (which is not mentioned so i have not opened any water area's except coolant tank)
    Thanks for any assistance.
    Kind Regards
    Adam
  2. Re: White smoke after 5 mins of driving, no obvious reasons
    Pembrokeshire
    22 Post(s)
    pop the carpet up in the boot and find the engine code. 3 letters should do.
    it obviously has a problem, and if whatever the problem is shows itself big time at 3am on way to the hospital, you will not be flavour of the month.
  3. Re: White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    Ha no i certainly wont be. Luckily the hospital is only 5-8 mins away, i'd have to get a taxi if the worst came to the worst. I cant get the engine code at the minute, the other half has it to do some last minute baby shopping. Personally i find it embarassing to drive ha.
    I'll give her a ring and ask her to get the code, hopefully it easy for her to get. Luckily my boot is completely empty except a baby seat.... If this was my last car, it'd have been a 20 minute job to get to see the boot's carpet
  4. Re: White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    OK apparently it's engine code BLS and Trans code? - KBL
    Adam
  5. Re: White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    Well it's definitely doing it more now. More smoke comes out when revving the car. Enough that people behind me back off!
    Any ideas? Oil ring? Although its not losing notable amounts of oil I assume it doesn't need much to smoke? What kinda cost am I looking at if it's injectors or oil ring? Shall I bend over get some lube and walk backwards into a garage?
    Adam
  6. Re: White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    Anyone any idea v? Would a vag com help?
  7. Re: White smoke after 5 mins of driving, no obvious reasons
    Aug 2012
    Newquay, Cornwall
    its worth a shot but i would have thought it will be more of a mechanical problem.
    its very strange that you havnt lost any coolant over 120 miles with the problem, and to make driver back odd it must be a hell of a cloud of steam. Is it defiantly white smoke (steam). Has it got a blueish tint to it. Is the car drinking much oil.
  8. Re: White smoke after 5 mins of driving, no obvious reasons
    Apr 2013
    Thanks for posting
    Well yesterday I took it to a garage and asked them to hook it to a vag com. They cleared 3 errors but didn't say what they were. I also added a litre of oil and some stop leak fluid. I dunno if the oil was leaking, it was low but I don't know how low it was before to compare. So I dove about 30 mile and it definitely smokes way less. Only smokes when I accelerate fast in low gear high revs. If I drive carefully it doesn't smoke. I can't tell if it's got a blue tint, looks totally white but it doesn't dissipate very quickly.
    If I'm stationary and rev it I still get small amounts of smoke, only when engine is warm. Also liquid does come out or exhaust will be dripping, it doesn't smell of anything if I dip my finger in it. Still no coolant loss though. Someone at shop said I might have a hole in my turbo hose letting air in and smoking? I have absolutely no power loss though. Possibility?
  9. Re: White smoke after 5 mins of driving, no obvious reasons
    Aug 2012
    Newquay, Cornwall
    White Smoke is actually steam so the guy at the garage dosnt know what he is talking about, if aditional (unmetered) air was entering the system it would show as black smoke as the engine is overfueling to compensate. I would have thought ERG cooler or headgasket but the lack of coolant loss is very surprising.
    I would think the next step would be to have the coolant system pressure leak tested to test for any leaks.
  10. Re: White smoke after 5 mins of driving, no obvious reasons
    Jan 2012
    Coding Something
    Let us know if the oil drops after the litre top up.
  1. Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    By Lbcvantage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-04-2014, 04:47 PM
  2. Squeaky Gear Selector after 30 mins of driving
    By silver4444uk in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2013, 01:16 PM
  3. Polo E 1L 'Y reg' - no throttle response after driving for 40 mins
    By dcee in forum Polo - Derby - Lupo - Fox
    Last Post: 25-01-2012, 10:28 PM
  4. ABS warning light after 10 mins of driving, V6 4motion
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2008, 01:48 PM
  5. White smoke
    By joegadney in forum Chat - Completely Off Topic
    Last Post: 12-11-2007, 06:51 PM
