Thread: Can "Coding" be done via VCDS?
Results 1 to 10 of 14
  1. Can "Coding" be done via VCDS?
    Jan 2013
    Reading
    Hi all,
    The below links to a retro kit for an original rear parking camera, it mentions in the notes at the end that coding is required and to speak to the dealer about this. Can this be done via VCDS?
    http://www.kufatec.co.uk/shop/en/Aud...?tab=anleitung
  2. Re: Can "Coding" be done via VCDS?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by EvilPostIt View Post
    Hi all,
    Complete bundle Audi rear view camera-38025
    I would guess so, yes. I'd hazard a guess that it will mean recoding one or two modules. Might be worth searching in the C6 section also - I seem to recall there may be one or two who have done this mod?
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Can "Coding" be done via VCDS?
    46 Post(s)
    I see no problem with coding that in!
    Maybe a change in the CAN gateway and the parking module.
  4. Re: Can "Coding" be done via VCDS?
    Jan 2013
    Reading
    Hi Chris,
    Could you explain a little more? What is the CAN gateway etc?
  5. Re: Can "Coding" be done via VCDS?
    Jan 2013
    Reading
    Ignore what I said above, have found a copy of the installation instructions online and it also seems to have instructions at the end of how to do the coding through VCDS... Its in german but I believe there is an english manual floating about, flick to the last pages, this seems to be the VCDS coding, is this correct?
    http://pdf.ampire.de/kufatec/38025.pdf
  6. Re: Can "Coding" be done via VCDS?
    46 Post(s)
    Yep that's the coding but through VAS - the dealer tool.
    If that has it then vcds will too.
    Can gateway basically tells the car what's installed and each major part will have a control module which the CAN gateway controls as a central hub.
    Sent from my iPhone using Tapatalk 2
  7. Re: Can "Coding" be done via VCDS?
    Jan 2013
    Reading
    Anyone done one of these before and know how much of a pain it is? Im reasonable with a set of tools but equally can be a bit heavy handed and dont really fancy breaking a new car...
  8. Re: Can "Coding" be done via VCDS?
    Apr 2009
    Surrey
    183 Post(s)
    I have not done one but the AMI on my car was retrofitted using the Kufatec kit and I watched the guy do it on my drive. The dismantling of the dash (which from the instructions is the bit that would scare me) whilst involved seemed to be fairly straightforward providing you take your time. It also all went back together OK and no squeaks. One other thing you started this thread off talking about VCDS and coding. May not be the case for the camera kit but the Kufatec AMI kit came with a dongle that you plug into the VCDS socket in the drivers footwell and it changed the car settings to recognise AMI. I then have the dongle to use again should the car get reset at some point and it forgets it has AMI.
  9. Re: Can "Coding" be done via VCDS?
    Jan 2013
    Reading
    Quote Originally Posted by johnsimcox View Post
    Oh, that's a good idea. Although i suspect that wont be the case with the camera kit as the advert explicitly states getting it recoded by the dealer. Out of interest, you say a guy did it on your drive. Is this someone you called out who you could pass the contact details for or was it a mate?
    Would much rather that someone who knew what they were doing fitted it rather than me hacking about with it thinking that a hammer is the best tool...
  10. Re: Can "Coding" be done via VCDS?
    Apr 2009
    Surrey
    183 Post(s)
    It was someone who my dealer (Walton Audi) used as the car they found for me (they wanted a quick deal because of the discount I got) did not have AMI fitted. The guy they used was actually based in Swindon so fairly convenient for you. It would have done at the dealer before I got the car but the AMI kit didn't arrive in time. I don't have his details with me at the moment but will try and find them over the weekend and send them to you. Failing that I can put in touch with the person at the dealer who organised it all or it might be worth asking your dealer who they use for retrofit stuff as apparently retrofitting AMI is very common
  1. Individual VCDS "trick", anyone know why not for C6?
    By kristofferS in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-11-2012, 11:21 PM
  2. TCM "Coding Rejected", Why is VCDS saying this?
    By gtmech in forum VCDS - General Questions
    Last Post: 10-11-2012, 03:53 AM
  3. Please Help VCDS Lite Reporting "too many communication errors to continue" on Telephone module #77
    By Yemiboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-08-2011, 11:26 PM
  4. where is "parking module" in vcds? and needle sweep?
    By Killer passat in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-06-2011, 01:16 PM
  5. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
