Thread: turbo issue
Results 1 to 10 of 10
  1. turbo issue
    Dec 2010
    pontefract, england
    i have just recently replaced my turbo on a 2001 pd130. before it went there was plenty of power and was a dream. with the new one the turbo doesn't seem to kick in till 2500 revs and above, and while in 4th or 5th gear there is no power and struggles to get to 70mph. its like driving a bog standard diesel, sometimes i feel like getting out and pushing !!! i have checked from the site i bought it from and it is compatible to my car.
    before i start spending trying to resolve this issue, i thought i would ask others for possible solutions.
    thanks in advance
  2. Re: turbo issue
    Pembrokeshire
    22 Post(s)
    and where did this turbo come from ?
  3. Re: turbo issue
    Dec 2010
    pontefract, england
    i purchased the turbo from a firm in germany. http://wwww.atp-autoteile.de. when i input my cars details it said the following;
    indicates a required field.
    This item fits with these vehicles:
    This item fits 1 version(s) of the VW Passat 2001 B5.5,3B6 [2000-2005] Estate 1.9 TDI:
    Please check if your vehicle is in the list and if there is no restriction for your vehicle in the notes field.
    [show all compatible vehicles]
    Notes
    Important part details
    Make Model Year Variant Bodystyle Type Engine
    Engine Code: AVF<... VW Passat 2001 B5.5,3B6 [2000-2005] Estate Estate 1.9 TDI 1896ccm 130HP 96KW (Diesel)
    This listing is for part or sub-assembly number given below only.
    A quantity of 2 is recommended.
    Page 1 of 6 previous page 1 2 3 4 5 6 7 8 9 10 Next page
    Portions of the information contained in this table have been provided by atp-spareparts
  4. Re: turbo issue
    Pembrokeshire
    22 Post(s)
    ok, doesn't seem to exist. is it a genuine turbo, i.e. garratt. thing is, as long as the turbo fits and is a vnt rather than wastegate , then it should work.
    is this turbo of spurious chinese origin ?
    how much did it cost ?
    does it weigh the same as the old one?
    if it chinese and cost you 200 quid, then you have an expensive doorstop.
    personally i will only usually use turbo technics in northampton. have done for years and never had any problem.
  5. Re: turbo issue
    Dec 2010
    pontefract, england
    cost 335. its what they manufacture so its not a garret. came with 2 yr warranty. no idea what it weighed had it delivered to garage to be fitted.
    it works but just not in the right places when required.
  6. Re: turbo issue
    when in 4th and you lose turbo power , does the turbo power return when you slow down or does it stay gone once it happens ???
  7. Re: turbo issue
    Dec 2010
    pontefract, england
    it tends to stay gone once it backs off.
  8. Re: turbo issue
    Norfolk
    You need a vcds log of boost at wide open throttle from 1000 rpm to 4500 and slow down. That will show what the turbo is doing.
  9. Re: turbo issue
    Quote Originally Posted by malcolm385 View Post
    next time it does it , switch off the ignition , just for a second and back on , if boost comes back you have boosting issues either underboost or overboost and its possibly going into limp mode ?? , like martin said you need a scan to get some ideas of whats going on .
  10. Re: turbo issue
    Dec 2010
    pontefract, england
    thanks guys, i will try and get it hooked up to see what faults are coming up if any.
  1. 1.9tdi Turbo Issue
    By mick&sons in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-08-2012, 11:51 AM
  2. a3 turbo issue
    By gibbi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-08-2012, 05:57 PM
  3. Please Help turbo issue?
    By emleymonkey in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2012, 11:29 PM
  4. Please Help Possible turbo issue
    By gttdi1985 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-12-2010, 11:08 PM
  5. T5 Inherent Turbo Issue??????
    By norrs2 in forum The Commercial Range
    Last Post: 06-09-2008, 10:57 AM
