Thread: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
  1. what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    Apr 2013
    portsmouth
    would like to no what the causes are for above please
    from little research i have done i conclude that oil in fuel tank can only be tandem pump
    and fuel in sump can only be injector seals
    other theory is if i have a crack in cylinder head from fuel into an oil galley
  2. Re: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    london/ UK
    Faulty seals on tandem pump...
  3. Re: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    Apr 2013
    Glossop
    I had a 1.9 transporter that did this, I think start with the cheapest fix first. Mine was injector seals ended up at £80 for the seals from vw. Is there some sort of pressure test you can do to help? I remember I was lucky because the van went to rev up and "run away" managed to stall it just intime.
  4. Re: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    Apr 2013
    portsmouth
    mine was tandem pump i put a pump from working unit and cleaned the tank out
    thanks for you input guys
  5. Re: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    Apr 2013
    Glossop
    How did you find out?
  6. Re: what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    Apr 2013
    portsmouth
    Quote Originally Posted by Pimpinthepidge View Post
    i used a specialist technique basically guessed lol
    i ordinarily found the problem when i changed the fuelfilter on service i always put the filters in see threw bags and leave over night to my suprise i found it to have large content of oil
    i already had new injector seals so i went after the tandem pump
    so i started by cleaning the tank out with electric pump then wiped with rag and put few liters of fuel, i also made a see threw bit or return pipe from return going to a clear bucket and started up with the faulty tandem, fuel went black almost instantly (see threw pipe was a bad idea because it just looks like normal fuel) but bucket showed the oil content as it poured out the return
    i had a working tandem pump of another car and switched it done the same as above cleaned filter. after runnig for 20 min no oil so ordered a new tandem pump
    nice clean tank and lift pump
    engine oil has been changed but will do another one in few days to be 100% sure
  1. Fuel pump in fuel tank
    By Andyase in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-08-2016, 01:53 PM
  2. Question Fuel pump not working: Fuel tank pd130
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2012, 08:43 PM
  3. help on BLB fuel pump issue
    By alfie155 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2011, 12:19 AM
  4. Fuel Tank + Reserve Fuel
    By illestjt in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2009, 03:22 PM
  5. Engine oil / heavy fuel consumption
    By Brianm in forum Passat - Archive Topics
    Last Post: 04-12-2006, 10:45 AM
