Thread: Drl halogen bulbs
Results 1 to 10 of 19
  1. Drl halogen bulbs
    Apr 2013
    Dartford
    I have the xenon headlights with the halogen drl bulbs, these are very yellow. Has anyone replaced with something whiter, either led or a brighter bulb? Need to get them changed as you can't turn them off!
    Mk7 GT
  2. Re: Drl halogen bulbs
    Quote Originally Posted by pinsharp View Post
    I have the xenon headlights with the halogen drl bulbs, these are very yellow. Has anyone replaced with something whiter, either led or a brighter bulb? Need to get them changes as you can't turn them off!
    Mk7 GT
    Nope. Unique vw bulb (as with the DRL bulb on the mk6). Currently no aftermarket replacement available.
    DaveB
  3. Re: Drl halogen bulbs
    Mar 2009
    Essex
    As it's got the bi-xenons which do main beam, might the DRLs just be bog standard P21W bulbs as on my older A6 which has a similar set up?
    I know the halogen mk6 cars have the new fangled bulb that does DRL and main beam but the main bit is not required here.
    Best to check by having a look - should be easy to tell if the bulb looks just like a brake light bulb.
    In which case you could try a canbus friendly P21W LED bulb. Loads about. I tried but got jacked off with the errors and bulbs flickering randomly. I could have tried more but couldn't be bothered. Went back to halogens, albeit some brighter whiter ones.
    Whilst it was working it looked good.
  4. Re: Drl halogen bulbs
    Apr 2013
    Dartford
    Quote Originally Posted by EssexGonzo View Post
    Thanks for your input I will take a look at the bulb and report back.
  5. Re: Drl halogen bulbs
    May 2008
    The DRL light on the MK7 Golf (for models with Bi Xenon but no LED DRL's) is a PW24W not a P21W (see below)
    Golf MK7 Headlight by Sootchucker, on Flickr
  6. Re: Drl halogen bulbs
    Apr 2013
    Dartford
    Quote Originally Posted by Norbreck21a View Post
    The DRL light on the MK7 Golf (for models with Btheni Xenon but no LED DRL's) is a PW24W not a P21W (see below)
    Thanks for the information no chance of a brighter and white one of those then
  7. Re: Drl halogen bulbs
    Mar 2009
    Essex
    They're also used in BMWs so I'd imagine some LED examples might be found by googling........
  8. Re: Drl halogen bulbs
    Any chance of the same image/info on a normal non-xenon headlight?
    DaveB
  9. Re: Drl halogen bulbs
    Jan 2013
    Slough
    Yes, please, would someone post the same for non-xenon lights?
    Ta
    Dickt
  10. Re: Drl halogen bulbs
    May 2008
    Here you go chaps
    Golf 7 Halogen by Sootchucker, on Flickr
  1. Replies: 43
    Last Post: 08-08-2016, 06:56 AM
  2. How To Swap out the halogen bulbs for LED bulbs
    By dsnotts in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-09-2012, 10:10 PM
  3. Polo 6R DRL help - halogen type
    By hho87 in forum VCDS - Help Requests
    Last Post: 07-02-2012, 06:42 PM
  4. Halogen headlamp bulbs
    By gamichea in forum Passat CC
    Last Post: 06-07-2010, 07:52 PM
  5. Halogen lights with DRL- Not that bad actually
    By Satch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-04-2008, 09:08 PM
